View Poll Results: Will you join the buy?
No Way, 40hp gain is too much for me
5
11.63%
Yes I'm going to order one very soon whether there is a group buy or not
6
13.95%
Yes I'll get one if the group buy price sounds attractive
29
67.44%
Not right now but definitely going to do get one in near future
3
6.98%
Voters: 43. You may not vote on this poll
a Group Buy for Kleemann C230K Pulley Kit?
Old Feb 28, 2002 | 01:27 AM
cw203's Avatar
will it include the kit for c200 kompressor sedan?
Old Feb 28, 2002 | 07:43 AM
zimmer26's Avatar
1991 mr2 turbo, 2002 coupe
Definitely interested. How much are they - approx installed?
Old Feb 28, 2002 | 10:25 AM
Brandon @ Kleemann's Avatar
Former Vendor of MBWorld
Questions
cw203- The Boost system will work with the C200 without any issues.
zimmer26- About $1000 installed, $899 for the system, less than 2 hours labor time.
buellwinkle- If you are suggesting that you can cut spring steel with a hacksaw blade you have obviously never played with a spring. Springs are wound with specific compression rates- made possible by the pitch of the wind. This pitch may change several times in the springs length. The ends of the spring are wound to fit the perches. If you cut a spring (with a grinder) it will never sit correctly in the perch. This is the seriously poor solution to lowering the car- buy lowering springs.
Old Feb 28, 2002 | 11:14 AM
Buellwinkle's Avatar
Kleemann, I'm not going to argue that cutting the springs is not the best idea but they showed this on one of the car shows like Hot Rod TV. They said to cut a small amount at a time and see what a difference it makes. I don't remember what they used to cut it but I thought it was a sawsall which is an electric hacksaw of sorts. Personally for $250 for four springs it wouldn't be worth the time and effort and I would want to keep the factory springs in case I wanted to go back to factory height. Ideally changing the springs is not the best way to lower the car anyway. They should have drop spindels or another means of lowering the car that preserve the suspension geometry and suspension travel.
Old Feb 28, 2002 | 11:24 AM
zimmer26's Avatar
Last question:
Where?
Old Feb 28, 2002 | 03:02 PM
BlackC230Coupe's Avatar
Fast Cars!
lowering
Buellwinkle ARE U CRAZY it does not take an hour labor to lower a car especually a mercedes. i bought the H&R springs for my coupe and i called 6 different places and they all said that it takes 5-6 hours labor. Even RennTech told me that. 1 hour is un heard of.
Old Feb 28, 2002 | 03:43 PM
  #32
Mach430's Avatar
It typically takes around 4 hours to change the springs and shocks.
Old Feb 28, 2002 | 03:54 PM
  #33
Fast Cars!
springs
so why did eeryplace tell me 5-6 hours? for just springs
Old Feb 28, 2002 | 04:05 PM
  #34
mdp c230k's Avatar
2002 c230k
It takes an hour PER spring, thus 4 hours. It is about the same amount of work to replace the struts as it is to just do the springs, sometimes its easier as you install the unit as a whole. To do just the spring you must take out the entire strut unit, compress the spring remove it, put the new spring on (compressed) and return it to the car. Even with no load on them the springs are under pressure, meaning compressed. If you dont have a proper spring compresser, dont try to half-*** it as you could really hurt yourself or something nearby when the spring breaks loose and shoots out.
Old Feb 28, 2002 | 04:40 PM
  #35
C230K's Avatar
C250 Coupe 2012
Guess I was right about the cost,maybe in time the price will come down, i just wait. After market stuff will be more available at reduce cost, just to new of a car right now.
Old Feb 28, 2002 | 05:40 PM
  #36
I'm just going by what Mark Cummings said. He installed the H&R set himself in less than an hour.
Old Mar 1, 2002 | 09:34 PM
  #37
WyattEarp's Avatar
2006 MB C230 SS 6spd, Navi
Are we gonna buy these? I see at least 33 units. That really only about 29000 though. Who's gonna negotiate it?
Old Mar 1, 2002 | 09:50 PM
  #38
gab's Avatar
gab
Evosport people and Kleemann people constantly checking this board and since they havent done anything yet so I guess they dont "buy" the groupbuy
Old Mar 1, 2002 | 10:01 PM
  #39
young's Avatar
GLB 250 4matic
https://mbworld.org/forums/showthrea...&threadid=3476
mach430 states,
<b>Sorry to burst everyone's bubble, but Kleemann products are sold at a fixed price, group buy or not. To get a 20% HP/Torque increase for only $899 is a great bargain already. And while some may think that $8000 is too much to spend on a supercharger, remember that you will get more power than a 430, for less cost.</b>
Old Mar 2, 2002 | 12:23 AM
  #40
Spyke's Avatar
2002 C230k
You can get away with cutting springs on some cars because they use a formed spring perch which is compatible with a, ah, um, err, a cut off spring that doesn't have a flat end, but I think most springs these days are cut in a way to be used on a flat perch.
In any case, I won't be cutting my springs any time soon! Ok, I won't even be getting a car anytime soon, but still. (Though I am kinda worried that the C7 wheels will look a bit strange without lowring the car a touch...)
Old Mar 2, 2002 | 12:40 AM
  #41
Norm C32's Avatar
ex-C32
Chris, good choice of bikes and car colors!
'02 C32 - Bordeau/Merlot
'00 ST4 - Red(of course)
