W203 heated seats, Is it possible
Old May 7, 2010 | 03:29 PM
mkoerner's Avatar
2K6 C230 Sport
Question W203 heated seats, Is it possible
I have a question that I think I know the answer to.
Is it at all possible to install the facotry heated seats into my 2K6 c230?
Is the car already wired for heated seated seats? Can I just buy the heater pads and front switch panel? I would say it's impossible but, you never know.
Old May 7, 2010 | 07:16 PM
Utahkompressor's Avatar
W124, W203, W204, W251
Use the search option...this question had been answered before.
All I remember is it's not an easy job!
Old May 7, 2010 | 10:17 PM
c230yvr's Avatar
Not impossible at all. Had it done in my car.
You need the heating pads and a new switch row just like you said. You might need a fuse too.
Installing the pads is a lot of manual labour. I had Sunil do it but after seeing him do it, I would do it myself next time. The rest is easy.
Old May 8, 2010 | 01:02 AM
hanknum's Avatar
'02 C320 Wagon, '78 308 GTS, '06 Highlander Hybrid
If you are interested in doing this please let me know. I have Recaro seat heaters that I intended to put in another vehicle. I reupolsterd the seats and never put in the heaters. I'll make you a deal on them
Attached Thumbnails W203 heated seats, Is it possible-dsc00714.jpg   W203 heated seats, Is it possible-dsc00715.jpg
Old May 8, 2010 | 01:17 PM
BF_JC230's Avatar
2005 w203 C230
Heat pad is sewn into and part of the w203 seat cover.
Search is the BEST tool here - as people have gone after market, installed rear seat heat (SUNILP) and installed OEM front seat heat (CaptPaul)
Good luck!
Jake
Old May 8, 2010 | 04:13 PM
c230yvr's Avatar
For best heating, you would want to buy new covers with the pads sewn in as BF_JC230 suggests, however, this is significantly more expensive then simply placing aftermarket pads underneath your current covers.
Old May 8, 2010 | 05:25 PM
timmynabenz's Avatar
2006 C230 SS, 2006 S500, 2008 CLS550 Lorinser
Steve @ MbenzNL !!!
Old May 9, 2010 | 12:58 PM
capt_paul's Avatar
2013 C350 Coupe, 2005 C230K Kleemann Sedan, 2013 GLK350 4matic
You will need a new control panel for the heated seat controls (the panel with all the buttons below the center vent), new seat covers (bottoms and backs), and a wire harness.
I did it in one day once I had all the parts. You must take your time putting the new covers on so you have a smooth finish (no wrinkles). You do have to pull out alot of things like the center console, seats, and the center stack (radio, climate control, switch panel, ash tray) in order to route the wire harness.
I have had the retrofit for several years with no problems. I got the harness and the seat covers thru Steve. If you do a search, you will see other people who have done the install. I do highly reccomend that you buy the MB Maintenance CD before you even begin to see if you are up to it.
Old May 10, 2010 | 08:09 AM
BF_JC230's Avatar
2005 w203 C230
Originally Posted by timmynabenz
Steve @ MbenzNL !!!
See above!
Old Jan 11, 2017 | 11:42 AM
DeVasto's Avatar
C-class w203 c200 kompressor
Hello.
Im digging this 7 years old thread. :P
I have recently bought leather interior with heated seats for my w203 and I also got myself panel switch. But I struggle to get a wire harness to get things connected. Does anyone know where I can get one? I swear I tried 20 breakers and none of them had it!
Old Jan 12, 2017 | 01:01 AM
Holmes5518's Avatar
2016 C450
Originally Posted by DeVasto
Hello.
dealership. It's not expensive.
Old Jan 12, 2017 | 03:21 PM
DeVasto's Avatar
I called dealership and they gave me quote of £1.500
do you know the part number?
Thank You
Old Jan 12, 2017 | 08:55 PM
miike's Avatar
2002 G500, 1961 190b, 2001 SL500 Sport
I installed aftermarket heated seats for $40. You don't need to replace the leather, if you put a heating element under the leather it works great. In fact, it's too hot on the hotter setting.
Soon I will be changing over to the factory switches. It will cost $40 for a switch panel and $80-100 or so for the wiring harness. So all in you could do it for $175. The dealer has to sell you all new leather so it costs more through them. They have no choice - can't sell aftermarket kits.
Old Jan 12, 2017 | 11:45 PM
Holmes5518's Avatar
2016 C450
Thank You
I Have the part number. I cab get it tomorrow. The quote they gave you is for the leather seat covers with heating elements.
Old Jan 13, 2017 | 01:13 PM
DeVasto's Avatar
Thank You for reply guys.
As I mentioned earlier I already own heated seats and panel switch.
All I need is original wire harness to get them connected.
MB dealer told me there is no separate wire harness for heated seats and I will have to buy main wire harness which will cost me 1.5k
He also said there is different versions of them?
I don`t know what they are smoking there but its definitely good thing.
I have 2002 w203 1.8 petrol (c200 kompressor)
Part number would be very helpful.
Old Jan 16, 2017 | 10:29 AM
DeVasto's Avatar
@Holmes5518
Part number would be awesome?
Thank You
Old Jan 17, 2017 | 11:44 PM
Holmes5518's Avatar
2016 C450
@Holmes5518
Thank You
sorry man, keep forgetting. Shoot me a text tomorrow at four one two 592 eighty five 97
