Low speed/tight turn rumbling shuddering from rear (W203, W211, W220)
About a month ago, started noticing a rumbling/shuddering from the rear on my '06 C280 4M when doing tight turns at very low speeds (parking etc). My brake sensors came on around the same time, so I thought it must just be the rear brakes. I replaced the pads all around, and the noise was still there, getting a little worse.
Anyone have any experience with this? Warranty passed (should have bought the extended, but I screwed up, I thought they said 75,000, not 50,000--my mistake). I'm at 59,000. To replace the oil is about 90 minute job, plus oil, so I'm guessing around $300. But if that doesn't work, replace transfer case, which sounds like a big bill.
Any chance of making a pitch to the dealer to fix this? If it was identified as a design or equipment/material problem in January, 2009, seems like there should be some liability on their part to fix it, even if the warranty is over now.
Anyway, thought I'd post the Technical Service Bulletin in case others are looking for answers on this issue.
Thanks for any info.
FraK
I didn't bother with the warranty stuff--if it needed a new transfer case, I would have though, but for $180, it didn't seem worth it.
Cheers!
I'm surprised this isn't an official recall yet--how often does a failure have to occur before they acknowledge it and fix it?
Keep us posted.
FraK
