Trunk auto popping open problem 2003 C240
I searched the forum for this issue, when you press the trunk release, either via the key fob or the button on the driver side door, that the trunk unlocks but doesn't open UP by itself.
I found that there are spring settings behind the trunk liners. first, the driver side setting was on the middle hole, and the passenger was on the first (least tension) hole. I have played around with them where i set both to the max tension, and of course the trunk popped open by itself!!!
Now you may ask yourself, why is this idiot posting this question if he already solved the problem. That is a very interesting point, with that setting, i noticed that the trunk opens so hard, it almost looks like it is going to smash the back window. Not something i would like to happen. Not sure it has that full range of motion to do so, but i dont want to take the chance.
So what is my solution? can i set both driver and passenger sides at different tensions? I tried max on driver and middle on passenger side, and it wasnt enough to bring it up by itself.
as a side note, I only recently purchased this car, it has a spoiler on the back, so i m wondering if that factory or was installed after the fact?
maybe the 03 models should be able to pop open like the newer ones?
thanks all for the help
2003 does not have a spoiler. previous owner probably added it. stock tension is set for one without a trunk spoiler. if you have a trunk spoiler just set the tension higher.
If that doesn't work then you might need to change your spring. Patrick's still didn't work.
You certainly know much more about the mods on this car then I do.
I had no clue about a body kit. The wheels are ok, i would have been ok with stock wheels, but since it came this way, ill take it. 18" btw.
What do you mean by the drop? sorry if thats a silly question
Your car sits more like a stock sport suspension. Overall, your car looks alot more like a facelift sport model.
Anyway, i love my little ride, i think i did pretty good.
As for the car, it really is nice looking. I can pass on the rims, but they're pretty subtle and match so it could be much worse (glad it isn't).
Good luck
I ll look into the headlamps. Silly question, Bix?
If so, where would I be able to purchase them? and what benefits do you see?
