Down shift, check engine light, V8 grumble, power loss, and a burning smell. (20 sec)
For 30 bucks if you get 5 or 6 years out of the non genuine part you have done well.
Sometimes you just pay a hell of a lot for the name. As long as they give you a direct equivalent for the car which I see they have on their website although they show the wrong picture.
I suppose it could be a glitch in the engine wiring harness or a bad connector somewhere - but I would expect this to give random trouble not only at full load peak RPM. I would also expect it to throw up trouble codes & it is not!!!! In fact I would expect most of the other possibilities to throw codes & they are not.
I guess all we can do is wait & see. I really want this to work for you so that you can enjoy your car!
I thought that KrisV420's car was a pain to sort out & we got that right but yours has been far more difficult with a complete lack of trouble codes apart from the misfire. I don't think we have wasted your money yet. The items we have serviced so far generally needed to be done at your mileage anyway. Last edited by Glyn M Ruck; Aug 6, 2010 at 08:59 AM.
Secondly, the misfires are still happening. I have just about given up.
Things replaced/tested/done to rid of Cylinder 4 Misfire:
All plugs.
Swapped coil packs.
New plug wires.
Air filters.
Cleaned MAF
Compression tested.
Injector for cylinder 4.
Changed fuel filter.
2x tanks of techron treated fuel.
Resealed both gasket covers and replaced driver side breather hoses. (Stopped oil from misting onto the coil packs.)
I've spent too much to carmax this car, and I wouldn't have the heart to do it, either. I don't know where to go from here!
Lane - read this - refer to it often when nonesense is spoken. The European motoring scribes agree with you & I. Enjoy your car. The C240 was extremely popular in Asia as well - That's not surprising from the oldest civilisation on the planet!
https://mbworld.org/forums/attachmen...ws-c-class.pdf
back to topic, so the injector on the #4 was the culprit after all.
All plugs.
Swapped coil packs.
New plug wires.
Air filters.
Cleaned MAF
Compression tested.
WITH all the parts replaced, the only cause for the misfire would be not enough fuel (running lean) which causes the ECU to shut that cylinder down to prevent detonation OR not enough air causing too rich of a mixture which would also causes the ECU to bring the misfire code and shut the injector down to prevent flooding the cylinder.
now, since you did replace all the parts with new parts, so I can safely assume that everything should be working properly and as it should. It leads me to believe that a ECU glitch is causing this problem for you. It is uncommon, but when I had my cam replaced last summer this was brought up by my tech that they have seen few cases of ECU causing misfires and when they replaced the ECU everything went back to normal.
ECU would be of course expensive. What I would do before you decide to buy a new ECU is check for ALL the connectors going to the ECU to make sure all the pins are properly connected and none of them are bent or broken AND have someone with STAR reflash the ECU to it's original state and see if that will still bring you the misfire code on full load.
1) Are you correctly identifying cylinder No 4? Quiz
which is cylinder 4? Explain2) Do you know anybody who would loan you their MAF for a test drive?
Hang in there!
I know no one who has a c240.
ECU reflash.. is it something quick with Star? For instance, can I just go to my dealership and ask they do it like they did my xenon=present settings?
EDIT: woah woah woah! They make an under-drive pulley for the 240? Or does the brabus kit include a blower?
- I had to checkWe'll worry about pulleys later. I think the pulley that Frank is talking about just underdrives the accessories.
Why did this car run fine for 400 miles after changing the filter
under-drive pulley kit is made by evosport. purpose is to under-drive the accessories so it ease the workload on the crank. you should see a 15hp crank improvement. i drove his car before and after, you can definitely feel the difference. for $400 ish, you can't beat the result. his Brabus stuff are the front/rear bumpers, muffler, puddle lights, and minor badging.
There are actually quite some stuff you can do to the M112 even in the 2.6 form. Brabus has a B9 kit which replaces the cams and tunes the ECU. Kleemann has the supercharger, and a lot of ppl now makes headers for the m112. believe it or not it's not hard to get to 200hp at the crank on the 2.6
You must remember, too, my car drove fine when I first changed the plug wires and plugs, but went to China, and upon return, the misfire returned, too.
I'm noticed if I baby the car for a hundred or so miles, I can get very, very lucky and maybe hit through first gear at max rpm's without a misfire. Probably just luck and in my head.
I can rev it in neutral while the car is moving, and redline it, no issues. Just under load.
This question is a forlorn hope.
I don't recall just filling up. No, I did not. I wasn't near a gas station.
When I swapped fuel filters, the gasoline was pretty clean, no crap coming out of the lines.
