draining oil from below vs mityvac
Old Jun 25, 2010 | 03:00 AM
phucmang's Avatar
05 c230k
i have to do a oil change, great, is there any benifits from the mityvac besides not having to get down and dirty? and i should use 0w-40? i already have a oil pan but no mityvac so i rather just drain if that is possible. is the oil pans drain plug easy accesable or do i have to remove the under panel or whatever it is..
Old Jun 25, 2010 | 03:10 AM
phucmang's Avatar
05 c230k
what else should i do on this service? just oil cahnge?
Old Jun 25, 2010 | 03:15 AM
W203E35's Avatar
2006 C350 Sport 6MT
Sucking the oil is much easier. You do need to take a cover off.
Mobil 1 0-40 Synthetic European Formula is what you need.
How many miles does your car have? You might need to change the air filter if you haven't done so (based on miles and last time you changed it)
Old Jun 25, 2010 | 03:50 AM
phucmang's Avatar
05 c230k
about 110,000kms
Old Jun 25, 2010 | 04:06 AM
e1000's Avatar
a quarter mile at a time
Both extraction and draining methods have proven to remove similar ammounts of oil. Use whatever method you like best. I personally like the vacuum method because I don't have to get under the car, I don't have to replace the crush washer on the drain bolt, and since the oil filter is up top as well, the whole oil change only takes a couple minutes.
With that said, use only Mobil1 0w-40. Also, use a fleece filter from Mercedes or OEM equivalent.
Old Jun 25, 2010 | 04:33 AM
TemjinX2's Avatar
03 g35 coupe...........02 c32 Sold
just pump it...there's no real benefit in draining it other then the money you save on the pump. But the pump usually pays for itself after 3 uses.
Old Jun 25, 2010 | 05:25 AM
phucmang's Avatar
05 c230k
yeah looks like ill be draining it.. but will i have to put in exactly 5.8 litres?
Old Jun 25, 2010 | 05:29 AM
TemjinX2's Avatar
just put in exactly how much comes out. If your not sure...i would stop short a quart and just slowly add using the digital oil gauge. You don't want to put in too much oil or you'll have to drain the excess again.
Old Jun 25, 2010 | 05:31 AM
phucmang's Avatar
05 c230k
ok ill pour in 5.4 litres first, then check the dash oil gauge and fill up if too low..
Old Jun 25, 2010 | 09:30 AM
johnand's Avatar
Super Moderator
2007 C230SS; 2014 ML350 BT
Do a search under my username, and you'll see I did a test to see which gets more oil out drain vs. suction and I found they get out the same amount, so suction is the way to go for keeping it easy.
Old Jun 25, 2010 | 05:03 PM
Taiwanese's Avatar
2003 C230
Since you have 110,000 kms, don't forget to also do the following if you have not do so.
brake fluid
coolant
trans oil
air filter
fuel filter
spark plugs
Old Jun 25, 2010 | 11:33 PM
SunnyRayToronto's Avatar
2003 C230 Sports Coupe, Paprika Metallic Red, Auto, Pano, Leather
Phucmang, it would be nice if you list your location. Since you reported your milage in km,... I'll assume you're a Canucklehead, eh! Your car computer will give you about a month warning before it's time to change your oil (Service A or B). A cold freezing Canadian winter is usually at least 4 months long,... do the math. Do you want to get underneath the car in the winter? Even if you have a garage, its still not fun getting under the car when the garage floor is ice cold.
BTW,.... mityvac, Pela, Moeller and various other in-house brands seems to all be made by the same Taiwanese company. Thus if it's too difficult to get one brand in your area,... shop for one of the other brands.
Old Jun 26, 2010 | 04:11 AM
phucmang's Avatar
05 c230k
yeah i am in bc....
brake fluid
coolant
trans oil
air filter
fuel filter
spark plugs
wow i dont think i can do all those my self... maybe coolant and trans fluid..
i got some 5w30 laying around that i got on sale.. mobil 1.. is that okay to use?
Old Jun 26, 2010 | 05:31 AM
TemjinX2's Avatar
The stock spark plugs should last you at least 100k miles. I changed mine out at 110k and they still looked like they can go longer.
Old Jun 26, 2010 | 03:54 PM
SeaCoupe's Avatar
2002 C230K, 2013 BMW 328, 2015 BMW X5
I always do it under the car. Found a leak at my TCM simply because I was under the car.
Ed
