CEL P0243 Where is it?
Haven't posted in a while, but recently my car has developed a slight hiccup.
i have the m111, and recently I've had an issue with losing boost. Didn't think too much of it, the car just lost a bit of power.
But now the CEL is on, I took out my trusty obdII scanner and P0243 came up.
So it's the Supercharger wastegate solenoid A.
Can someone enlighten me as to where this is located?
Is it the so called "recirculatory Air flap" that's located on the front of the engine, beside the intake, under the oil catch can?
I'm thinking it's this because when I try to reset the "air flap" sometimes it fails to reset, just dosen't want to move.
Any info would be much appreciated!
Thanks in advance.
Dion
http://www.benzworld.org/forums/w203...2002-c230.html
I've reset the flap several times, haven't solved the issue.
I just want to make sure that the P0243 code refers to the correct part I want to replace.
