Tire Pressure Loss with STAR
Subscribe
Jul 25, 2010 | 08:41 AM
Request - Check out PDF document
Reply 0
Jul 26, 2010 | 09:38 PM
Cool thanks
Reply 0
Jul 27, 2010 | 01:26 AM
If I remember correctly, this system is a passive system. That means it doesn't actively monitor the actual tire pressure, it monitors wheel rotations. If a wheel has significantly more or less rotations, then that means the circumference has changed. Thus, the tire pressure has been adjusted.
Reply 0
Aug 10, 2010 | 03:04 AM
Can someone post again the PDF file, I can not see and download it
Reply 0
Aug 10, 2010 | 05:31 AM
Quote: If I remember correctly, this system is a passive system. That means it doesn't actively monitor the actual tire pressure, it monitors wheel rotations. If a wheel has significantly more or less rotations, then that means the circumference has changed. Thus, the tire pressure has been adjusted.
Correct. It isn't as accurate as an active system, but it does work as the American wife found out at 12,001 miles on rear tires that were good for 12,000 miles.
Reply 0
Aug 10, 2010 | 10:15 PM
Here you go
Reply 0
Feb 12, 2011 | 12:37 AM
Quote: Here you go
One more time please. Its gone again.
Reply 0
Feb 12, 2011 | 01:15 AM
Anyone have it? I can't find it on my computer and my STAR is down at the moment so I can't make one...for now.
Reply 0
Explore
Feb 13, 2011 | 03:24 PM
Quote: Anyone have it? I can't find it on my computer and my STAR is down at the moment so I can't make one...for now.
Hope someone else has it. If you can create it again from STAR what would be awesome. My car goes in Wednesday for a harness repair (damn mice!) and I thought I would get this activated. Having the procedure in hand would better guarantee it gets done!
Thanks again.
Reply 0
Feb 16, 2011 | 03:01 AM
Hey guys, I found one. If I recall correctly this was one that I did on the pre-facelift models.
I can't quite remember.
Reply 0
Feb 16, 2011 | 08:51 PM
Quote: Hey guys, I found one. If I recall correctly this was one that I did on the pre-facelift models.
I think this will help me get where I need to go with the dealer. My car is still there so I'll talk to the tech tomorrow. Thanks so much!!
Reply 0
Oct 3, 2012 | 09:29 AM
I managed to get hold of STAR and tried to enable Tire Pressure Loss Warner using the instructions above. I got to Control Units > Chassis > ESP > Control Unit Adaptations, but there was no option for Tire Pressure Loss Warner. Am i missing something? I keep hearing that something needs to be done before getting to the ESP part but i cant seem to find any instructions. Also i have a 2007 C280 4MATIC. I would truly appreciate it if you can shed some light.
Reply 0
Subscribe
Currently Active Users (1)
