HELP: Key Problems
Old Jul 28, 2010 | 02:37 PM
benzpride's Avatar
C240
HELP: Key Problems
Hey guys,
If someone could direct me on where to go/what to do.
So i got my c240 key wet and after had some problems with it, but it finally was recognized by the ignition BUT in order for me to open the car I have to put the end of the key next to the infrared on the car.
Is there any way I can fix it again, so I can open the car without having to be next to the infrared sensor?
Old Jul 28, 2010 | 02:45 PM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
Water is not the key's friend. You will probably have to replace it.
Old Jul 28, 2010 | 03:04 PM
govertime's Avatar
you could try changing the battery and/or taking the case apart and cleaning the circuit board with alcohol and lint free cloth. its probably worth a shot at the price these sell for.
Old Jul 28, 2010 | 03:14 PM
MW_ATL's Avatar
'02 C230 Coupe (Me) '03 SLK320 6MT (Wife)
Hmmmm. The infrared sensor should be for the convienece feature (opening closing the sunroof and the windows) and a radio signal should be used for the locking/unlocking, etc.
That is why some people with metallic tint have problems with the unlocking. I believe the antenna is near the upper part of the back window.
That sounds a lot more like the battery got drained on your key. Not sure why, but if I were you, I would try pulling the battery and all out of your key, letting it dry very well and trying a new battery.
Old Jul 28, 2010 | 07:13 PM
Glyn M Ruck's Avatar
Super Moderator
Read the many threads on RF failure/metallic tints. The RF side of the key is down. Wash out key with hot alcohol, give it a dry with a hair dryer (not too hot!) Put in new batteries. Does your spare key work normally? If so & you can't revive the troublesome one you are in for a new key. If they both don't work the whole rear window antenna, sticky contacts & antenna amplifier are suspect. The EIS inductively powers the key once in the ignition. Batteries play no part at this point.
Old Jul 28, 2010 | 10:54 PM
benzpride's Avatar
C240
I did dry the key and took it apart after I get it wet from water and was able to get it working. Problem is I had to take the battery unit and put it into my spare key (as the spare key battery was out). So now I am using the spare, which has the same body as the regular c240 key.
So hot alcohol and new battery? Battery seems to flash even when I am far from the car....
I'll read up on this, but I don't want to destroy the spare key, so I'll give it a shot on the original key that was damaged and see what happens.
Anyone who had a similar experience, chime in!
Old Jul 29, 2010 | 07:46 AM
Super Moderator
Does the spare key work from a distance?
Old Jul 29, 2010 | 12:44 PM
MW_ATL's Avatar
I've dunked my primary key several times, but usually followed the alcohol and dry out procedure immediately and it still works fine.
