New Rims and now I have a bunch of issues.
Old 07-28-2010, 10:12 PM
05 MB Komp's Avatar
2010 C350 Sport
I recently put a set of 19" Mandrus Milleniums on my 2005 C230 Sport Sedan. I do not have any rubbing in the wells but I have some new noises that I am having a hard time with.
The first one sounds like a rubbing sound that goes away when I press the brakes. As soon as I let off the brakes it comes back. It does not matter what speed I am going, I can still hear it with the windows down.
The second sound is rattle that happens when the car is put in gear and starts rolling. It sounds like a heat shield but I don't think it is.
Here is the confusing part. I took the new rims off because the car was involved in an accident and both the sounds went away. I put the stock rims on and there is no rubbing sound or rattle.
The only thing that is different with the new rims is the lug nuts they sent me. They were chrome dipped (even the threads) and very hard to install. I feel like the lugs are tight but maybe one of them isn't. Could this cause the sounds I hear?
Any ideas?
Old 07-29-2010, 01:48 AM
phister's Avatar
06 C230 SS 6spd
You're wheel bolts might be too long and rubbing inside.
Old 07-29-2010, 02:24 AM
infected's Avatar
2007 ML500
Probably the lugs hitting the parking brake.
Old 07-29-2010, 08:56 AM
Super Moderator
Glyn M Ruck's Avatar
Almost certainly the lug BOLTS are too long & hitting the rear parking brake mechanism.
Old 07-29-2010, 12:32 PM
05 MB Komp's Avatar
2010 C350 Sport
Thanks for the replies. If the lugs that came with the rims are too long where would I go for a shorter set?
I contacted the company that sold me the rims and they have no clue.
Does anyone know the correct bolt length for the rims I have. I need to order a set ASAP.
Thanks again.
Old 07-29-2010, 09:29 PM
EV0LVE's Avatar
F10
go to a reputable wheel shop, the one that knows aftermarket wheels and worked on european cars. you'll probably pay $5 per lug bolts. goodluck.
Old 07-29-2010, 10:13 PM
Beepbeep's Avatar
2007 C230, S2000
Thanks again.
I would try and compare the OEM bolt length to the aftermarket one and have a shop cut it to OEM length.
Old 07-29-2010, 10:18 PM
nobli's Avatar
07 c230
reputable repair shop is a good idea
Old 08-06-2010, 03:02 PM
05 MB Komp's Avatar
2010 C350 Sport
The rim company is going to send me a new set of bolts that are shorter.
The sound is back though. Still riding around with the factory rims and the sound is back. Did something get damaged? How do I go about checking the parking brake system out?
Is there a part number for new pads or shoes? I need this noise to go away.
Old 08-06-2010, 03:15 PM
Moderator Alumni
TruTaing's Avatar
w203 m112
probably damaged your parking brake system....
Old 08-06-2010, 03:32 PM
05 MB Komp's Avatar
2010 C350 Sport
Something I can fix myself or do I need to take it in to the dealership?
Old 08-07-2010, 11:42 AM
05 MB Komp's Avatar
2010 C350 Sport
Anyone have experience working on the parking brake system?
Old 08-07-2010, 12:30 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
You should really get it to shop. You don't want to cause any further damage
Old 08-09-2010, 02:50 AM
phister's Avatar
06 C230 SS 6spd
yeah take it to a good MB shop and have them look at it
Old 08-09-2010, 08:14 AM
Super Moderator
Pull the rear park brake rotor hats/drums & check.
See here:
https://mbworld.org/forums/c-class-w...mbly-help.html
Old 08-10-2010, 08:12 PM
MelbMerc's Avatar
C200 Kompressor A150
I did the very same thing a couple of years ago, cost me a handbrake!
Old 08-10-2010, 09:28 PM
05 MB Komp's Avatar
2010 C350 Sport
Was it an expensive repair?
Old 08-10-2010, 10:20 PM
MBworld Guru
FrankW's Avatar
white and whiter
avoid chrome bolts if you are getting new bolts.
check out rad-usa.com for quality bolts.
the rubbing sound can just be your pads getting worn.
the long bolts for the rear unless they are really long which creates a loud metal on metal clink/snapping noise you should be okay.
Old 08-11-2010, 02:10 PM
05 MB Komp's Avatar
2010 C350 Sport
Can I change the pads myself?
I had that clinking sound with the new rims and bolts on there. I only have the rubbing sound now with the old rims and bolts back on.
I will check out the site for some non chrome bolts. Any idea what size I need? The place I bought the rims from is having trouble figuring it all out.
Old 08-11-2010, 03:54 PM
Super Moderator
New rear pads is an easy change
Old 08-11-2010, 03:58 PM
05 MB Komp's Avatar
2010 C350 Sport
I guess I should have said the parking brake pads. I changed the rear brake pads earlier this year. They shouldn't need to be replaced for some time.
I would assume I just need to take the caliper and rotor off to changes the parking brake pads. Probably held on by springs.
Old 08-11-2010, 07:28 PM
Super Moderator
Yes - remove caliper - undo retaining screw in the hat - see diagram & pull of hat/rotor. The brake shoe setup is a minature of rear drum brakes from older cars.
Old 08-14-2010, 09:47 AM
MelbMerc's Avatar
$800 from memory, annoyed me because I'd settled for the cheaper wheels, in the end I spent the same!
Phil
Old 08-14-2010, 11:08 AM
05 MB Komp's Avatar
2010 C350 Sport
I found the parking brake shoes for $37 at Autohauz.
Gonna replace those first and see what it does. See if anything else is damaged when I take it all apart.
Old 08-14-2010, 03:57 PM
AllGoNShow's Avatar
Various....
Good start, get new shoes on while you have it all apart. Once you can finally see all the components you can see what has been damaged or broken.
Might be too late now but sometimes it's only one or two wheels causing the problems (should match lug bolts on all 4 corners to be safe when another shop touches them or you change out for winter), the best thing to do is grab a buddy and have him walk beside the car slowly as your moving, determine what wheel is hitting, what the sound sounds like outside.
Shorter bolts save lives & brakes.
Make sure you have minimum 6 turns from the first click of the threads.
Quick Reply: New Rims and now I have a bunch of issues.
