excessive wear outer edge of front tires???
Old Sep 8, 2010 | 11:42 AM
Glyn M Ruck's Avatar
Super Moderator
I'm not a great lover of Conti tyres but why don't you try a set of Extreme Contact DW's. They are a big improvement on older offerings & much cheaper than PS2's - my favourite tyre.
See Tirerack Survey.
Old Sep 8, 2010 | 11:44 AM
maverik259's Avatar
05 C230K SS (sold), 06 C55 (sold), 08 Yamaha R1 (sold), 16 X5M
thought about it but they're running nearly 200 a peice. I'm trying not to drop 500 on 2 front tires and install if I can help it you know.
Old Sep 8, 2010 | 06:09 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
Originally Posted by maverik259
what tires have you guys had good experince with? I was looking at the nitto invo's...found pretty good deals on them on a site. That and I was also looking at the BFGoodrich G-Force
PS2, Hankook evo v12, Goodyear GS-D3 (discontinued), drove nlpamg's 203 on Eagle F1 asym briefly and liked it as well...
if you are going to spent T1R money, you might as well spent a little more for the Eagle F1 asym or the PS2.
but if you are going to save some $$ I highly recommend you try out the new Sumitomo HTRZ-III or the Hankook EVO V12. performance wise they are actually on-par with the T1R and just a little short of perfection from the PS2.
Old Sep 8, 2010 | 06:57 PM
maverik259's Avatar
what are the PS2? and I was actually looking into the Nitto INVOs
Old Sep 8, 2010 | 07:00 PM
maverik259's Avatar
ya and def not looking at spending $250 per tire...
Old Sep 8, 2010 | 07:04 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
drex has the nitto invos...he says they're too soft? lol
PS2 = Michelin PilotSport 2 = $300 plus a pop...lol
Old Sep 8, 2010 | 11:13 PM
  #32
maverik259's Avatar
ya i think im going with the hankook...found a set for 158 a piece and am gonna have sears install them with a roadhazarard warranty. then its off to hopefully find someone that can fix my suspension so this stops happening
Old Sep 9, 2010 | 02:37 AM
  #33
hanknum's Avatar
'02 C320 Wagon, '78 308 GTS, '06 Highlander Hybrid
When I lowered my '02 C320 wagon, I thought the negative camber would help even out the wear on the fronts. But, now I just have BOTH inner and outer wear. I've bumped up the pressure to 40 psi on the fronts and that seems to help a little. Actually, there was so much wear on the outers, that I'm not too sure how much it is still wearing after the drop.
Hopefully the fronts will last another month, then I'm going to replace them with the Hankook V12s. I've got Sumitomo HTR III on the rears now and they actually seem to be wearing faster than I thought they would. The rears are wearing evenly though. Once I've got new rubber on the fronts, I will be able to monitor the wear better.
Maybe my wife is a more aggressive driver than I thought
Old Sep 9, 2010 | 02:45 AM
  #34
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
for tires that are already wearing to a certain pattern it's not going to change how it wear even after you lower the car.
get new tires, get the control arm bushings checked, and get an alignment.
Old Sep 9, 2010 | 02:58 AM
  #35
TemjinX2's Avatar
03 g35 coupe...........02 c32 Sold
I agree with franks statements of the hankook evo 12 and ps2's. For the money the hankooks are a good deal.
Old Sep 9, 2010 | 09:42 AM
  #36
maverik259's Avatar
ya thats what im gonna do. after getting the hankooks on I'm gonna ask them to check the bushings while they're under there...I know alignment is legit cuz I just had it done 2 weeks ago...I bought a 3 yr unlimited alignment plan from Tire Kingdom for only $30 more than the cost of one alignment so I'm good on that front!
Old Sep 10, 2010 | 02:52 AM
  #37
hanknum's Avatar
Yeah, you're right Frank. The bushings are in good shape. I'll put on the new rubber and monitor it.
Hey, how come your post are always wider than everyone else? Everytime I read one of your post I have to cursor over to the right...how annoying is that
Old Sep 10, 2010 | 02:57 AM
  #38
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
it's because i stacked the gif in my sig to the right. no issue for me since i always full screen my browser.
Old Sep 10, 2010 | 01:12 PM
  #39
maverik259's Avatar
just ordererd the tires from sears. should be hear tuesday. While they're under there I'm gonna have them take a peak at the bushings and tell me what they think. MB wanted 300 to replace them (and I think thats per side). FML
Old Sep 10, 2010 | 05:30 PM
  #40
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
all four of my control arms plus the steering tie-rod was only $350. LOL
Old Sep 10, 2010 | 05:39 PM
  #41
maverik259's Avatar
at the dealer? and ya ONLY 350 soooo cheap...wow if only I hadn't just dropped 450 for these 2 new tires then I'd have 350 to spend replacing my suspension lol.
Old Sep 10, 2010 | 05:47 PM
  #42
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
from rmeuropean. installation was another $150 ish from my parent's mechanic friend.
Old Sep 10, 2010 | 08:19 PM
  #43
maverik259's Avatar
oh so parts were 350 and 150 for install? jeez!
Old Sep 15, 2010 | 05:16 PM
  #44
maverik259's Avatar
just got installed today as well as an oil change...talked to the techs there and they foudn nothing wrong with my bushings or suspension and suggested that perhaps my camber/caster is jacked up and needs an adjustment...anyone have an idea who can do this...normal alignments only fix toe angles apparently according to him. At least theirs, firestones, and tire kingdoms...can the dealer fix it with an alignment or they gonna rip my leg off beat me with it and then fix it ?
Old Sep 15, 2010 | 07:12 PM
  #45
Super Moderator
The techs are talking crap. Fit fluted bolts to both castor & camber bushes & take the vehicle to a decent alignment shop.! Grrr! Where do they find these idiots. Firestone can do it.
Old Sep 15, 2010 | 08:26 PM
  #46
maverik259's Avatar
so I have to change the bolts for them before they can be adjusted?
Old Sep 15, 2010 | 09:37 PM
  #47
Super Moderator
In South Africa every alignment shop carries Benz bolts - In fairness it is the 3rd best selling brand here after Toyota & Volkwagen.
Buy the bolts & take them along to your alignment shop & they can pop them in when setting the castor & camber. Print out the Benz explanation from the castor/camber/crash bolt thread under the DIY stickies & stick it under their nose in case they don't understand how to use them.
Old Sep 15, 2010 | 10:23 PM
  #48
BenzteK82's Avatar
C230 Sport AMG Kit , 06 F-150
I recently installed 2 Bridgestone Potenza RE760 Sport rear 245/40/17 on my c230 and the are sweet!
Old Sep 15, 2010 | 10:26 PM
  #49
BenzteK82's Avatar
As for the alignments....I would just take to the dealer! Other shops are dumb and dont know how to treat a real car! BENZO 4ever!
Old Sep 15, 2010 | 10:32 PM
  #50
TemjinX2's Avatar
i got my alignment done at discount tire and it was fine. The mechanics of the car is the same as any other car. No real need to pay the premium of a dealership alignment when other places can do it cheaper.
