error message tail lamp
Old Jul 29, 2010 | 11:20 PM
jerryml430's Avatar
2006 c230
Exclamation error message tail lamp
hey everyone,
so today i got the error message for the brake lamp left side and i did replace it. after couple minutes i got the 2 error messages, the first one is tail lamp left and the second one is tail lamp left substit, bulb on. any idea whats going on?
Old Jul 29, 2010 | 11:49 PM
ontmiss's Avatar
2007 C280 4matic Avantgarde
It's on same side where you changed brake lamp. Check the connector if it sits properly
Old Jul 30, 2010 | 01:37 AM
jerryml430's Avatar
2006 c230
so there is only one connecter for each side which is the one you are talking about unless there is something that don't see, right? if i'm not mistaken i just did the check up and it's connected. whats funny now is that i'm getting 2 more messages which is say the same thing for the right side. So now its for left and right, what should i check next?
Old Jul 30, 2010 | 01:53 AM
Gynecologist MD's Avatar
Hopefully another MB soon..
If the replacement/substitute lights are on, then your main brake lights either don't have connection or are busted
Old Jul 30, 2010 | 02:56 AM
TemjinX2's Avatar
03 g35 coupe...........02 c32 Sold
just check the plate...where the bulbs sit. Some times corrosion builds up and produces additional resistance causing a code. You can just get a pencil eraser and wipe off the corrosion.
Old Jul 30, 2010 | 03:31 AM
jerryml430's Avatar
2006 c230
well the brake lights and the signal lights is working fine, its just the tail lights. so if there is no connection then the brake and signal lights won't work too. right?
Old Jul 30, 2010 | 03:34 AM
jerryml430's Avatar
2006 c230
i'll check on that, but the problem is that the tail lights on both side is not working. It's not just the error messages and i checked the lights bulbs and it look fine on both side
Old Jul 30, 2010 | 05:39 AM
Glyn M Ruck's Avatar
Super Moderator
If all the lamps are the correct value - Then as TemjinX2 says it is a poor connection. Try the eraser route or spray the connectors with some switch cleaner when disconnected & reconnect.
