front differential right side axel seal???
2003 c240 4matic wagon
wheile had my front axels replaced due to cv joints/boots being wrecked after they pulled the right hand side shaft 3 weeks ago I noticed on friday that the seal is now weeping its not leaking enough to drip (yet)
has anyone replaced the axel seal on the front right side diff??
Super Moderator
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
![](https://mbworld.org/forums/attachments/c-class-w203/190140d1282408455-03-c240-4matic-front-differential-drain-fill-plug-4matic-front-diff.jpg)
![](https://mbworld.org/forums/attachments/c-class-w203/190239d1282570107-front-differential-right-side-axel-seal-4matic-front-drive-shaft.jpg)
That's 170 & probably 100 on the diagram. Never done it but probably not too bad to do. See what others post.
Part numbers:
10 A 203 330 03 02 AXLE HOUSING 001
50 N 006798 8006300 .SERRATED WASHER
BREATHER 001
60 A 210 330 00 89 .BREATHER 003
80 A 210 997 01 40 .SEALING RING
LEFT 001
100 A 028 997 55 48 .SEALING RING 001
110 A 210 990 01 51 .NUT 001
120 A 210 997 08 45 .SEALING RING
76X2.5 MM 001
130 A 210 335 00 60 .SEALING RING 001
140 A 210 981 02 05 .TAPERED ROLLER BEARING 002
150 N 910105 5008012 .SCREW
M8X30 004
160 A 210 330 02 44 .COUPLING FLANGE 001
170 A 210 997 00 40 .SEALING RING 001
180 N 910105 5008005 .SCREW
M8X25 005
190 N 910105 5010011 .SCREW
M10X40 002
200 N 000908 8018011 .SCREW PLUG
M18 X 1.5 001
210 N 007603 3018101 .SEALING RING
18X22-CU 001
250 N 910105 5010011 SCREW
FRONT AXLE GEAR MOUNTING
M10X40 006
260 N 000000 0003492 DOWEL PIN
12X32 001
260 N 302338 8012000 CYLINDRICAL PIN
Replaced_By: N 000000 0003492 001
I ordered the seal it was back ordered I got this seal A 210 997 01 40 which I think is for the left side Not the right side like i requested
so can anyone confirm this????
Super Moderator
I've never done this job. I thought 170 was the RHS seal??? Big difference in seal size - yes
Super Moderator
Just checked. 170 is the output shaft seal for the RHS - The reason they use such large differences in output shaft size is to offset torque steer.
P/N A 210 997 00 40
P/N A 210 997 00 40
