how to check the differantial fluid?
Old Aug 29, 2010 | 03:26 PM
genius's Avatar
2003 c240 4matic
how do you check the differantial fluid?
what color is it?
If it is low, where to add it?
Old Aug 29, 2010 | 03:52 PM
pcy's Avatar
pcy
'14 ML350, '13 C220 CDI, '07 C280, '98 ML320
Typical differential has a drain plug (to remove the fluid) and a fill plug (to fill the new fluid). After removing the old fluid via drain plug and putting back the drain plug, you'd pour the new fluid via fill hole until the fluid starts coming out. The fill hole is at the max level of the diff fluid. So, you won't be able to over-fill of you try to.
Please note that some differentials (like the front diff on my front '07 C280 4Matic) have just one plug - for removing the fluid and adding new fluid.
Old Aug 29, 2010 | 04:01 PM
genius's Avatar
2003 c240 4matic
thanks for the info and appreciate it.
but is there a dip somewhere to check the amount?
also what color is the fluid and what kind do you use?
Old Aug 29, 2010 | 05:35 PM
Glyn M Ruck's Avatar
Super Moderator
https://mbworld.org/forums/c-class-w...fill-plug.html
30 is level plug
Axle fluids should meet Benz approval 235.7 Part number A001 989 33 03 10 or approval spec 235.9 - Available at your Benz dealer.
Attached Thumbnails how to check the differantial fluid?-matic-rear-diff.jpg
Old Aug 29, 2010 | 05:42 PM
Super Moderator
Here's the tranfer case - more complicated. Diffs are dead easy
I hope you are a genius
You have some work to do.
Old Aug 30, 2010 | 12:29 AM
lkfoster's Avatar
’27 AMG SL55(ordered), ‘23 EQS 580 SUV, ‘19 AMG E53 Cpe, ‘48 Willys Jeepster
30 is level plug
I had planned to change my rear diff oil with Mobil 1 Synthetic Gear Lubricant LS 75W-90, but now you've got me wondering if it's the right oil. The Mobil page doesn't say anything about 235.7. Will this thinner oil be OK? I live where summer temps get up to the mid-40s C.
Old Aug 30, 2010 | 07:05 AM
Super Moderator
The 235.8 spec is for 75W-90 so that's correct viscosity. I thought the Mobil was approved - will take a look & report back
Please note I meant 235.8 above & not 235.9
Old Aug 30, 2010 | 09:28 AM
pcy's Avatar
pcy
I thought that MB recommends 85W-90 diff fluid...
Old Aug 30, 2010 | 09:35 AM
Super Moderator
Steadily changed over time to one size fits all for all temperature conditions & as high VI synthetics have become available. i.e. behaves like a 75W when cold & like a 90 when hot.
Synthetics thin out less with increased temperatures over normal petroleum fluids.
Old Aug 30, 2010 | 09:44 AM
contact148's Avatar
2003 c240 4matic wagon
you might not be able to find any mb spec fluid I was unable to get any in canada (had to import a case from usa) way to much $$$ to do that
so I used valvoline same as the 2 local dealer use here.....
Old Aug 31, 2010 | 05:25 PM
97W202's Avatar
2006 C230 6speed/14 C63
how often should this fluid be changed?? thanks!
Old Aug 31, 2010 | 08:13 PM
Super Moderator
Every 75 to a 100,000 miles is a good call.
Old Aug 31, 2010 | 08:27 PM
OneOfaKindTrini's Avatar
Nike Turbo Shox
You guys should look into AMSOIL for your diff.
Old Aug 31, 2010 | 08:57 PM
Super Moderator
AMSOIL does not hold a Benz approval as of today's listing.
