Trunk Lid Won't Swing Open
c200 Kompressor
My trunk lid used to swing open when the release button is pressed.
I noticed recently that while it unlocks when the release button is pressed, it no longer swings open.
Is there an adjustment to tweak inorder to let it swing open?
I tried the following
1. lubricated the hinges thinking they could have been sticking
2. cleaned the rubber moulding
still same.
still same.
There are 2 heavy springs on both sides attached to the 2 arms that attach the lid to the body/frame. One way to solve the issue is by lubing those springs (where those springs are attached) OR by replacing those 2 springs.
I am referring to the part labeled #90 in the picture attached below.
c200 Kompressor
Great to have Service Manual.
Now I know what to look for.
Many Thanks.
Great Help.
Super Moderator
John and Glyn, I didn't know that those springs can be adjusted. Thanks to you guys, I now know. I will try to adjust the springs on my car's trunk lid this weekend :-)
sirei808, I suggest you also adjust the spring (lubing the spring won't bring back sagging spring).
13 Jeep JKU Sahara w/4" lift Kit & the works,2015 Toyota Sienna XLE,2013 Hyundai Sonata Hybrid
thanks for letting me know that there is adjustment to the spring, ever since I installed the spoiler the lid does not pop it juts unlocks and stays there..........now i know..........
I just changed the spring attachment location. I moved the spring to middle position on one side only and the lid deck snaps open nicely. I will move the other side spring later when the lid doesn't open fully.
Excellent. Thanks John and Glyn :-)
c200 Kompressor
This Forum is GREAT!
I also did as JOHNAND recommended.
I did 1 notch adjustment and the trunk lid opens now.
Very good observation there my friends!
Thanks a lot!
Javvy, if it is that sensitive, now I know why it stopped swinging open on mine.. i added a chrome plate holder.
so much with MODS.
Thanks a lot!
so much with MODS.
c200 Kompressor
I checked last night and noted that the left spring has been moved to the 3rd position, but the right spring is only on the 2nd. Moved the right to the 3rd slot and now rear trunk cover is swinging full open from release.
Many thanks guys.
Many thanks guys.
