05 SLK 350 Calipers rebirth
I got these calipers from a fellow member. This pictures show what some time and patience can produce.
The one on the left is as received. Then bead blasted on the right.
![](http://wardsweb.org/cars/C240/amg_caliper1.jpg)
The final product - calipers painted and bolts polished.
![](http://wardsweb.org/cars/C240/amg_caliper.jpg)
It will be next weekend before I can bolt everything up. I've got the calipers ready, factory brake fluid and factory cross drilled rotors but still waiting on the new pads.
I don't know if this could be a stand alone DIY. You see the original in the picture. I bead blasted them as you see in the first pic. I masked off the interior portion of the calipers and spray painted them with caliper paint. I let it dry for two days and applied some decals I got off ebay. The last part is purely esthetic and that required a 3/8 drive 50 torx. I removed them one at a time, polished and reinstalled, as not to break the seal on the caliper. They were polished on my bench grinder fitted with a cotton wheel and some white tripoli.
