Continental ExtremeContact DWS
http://www.tirerack.com/tires/tires....emeContact+DWS
Question: What air pressure are users of this tire running? My OEM stock Conti ProContact's are 30 front and 32 rear as stickered on the C280. Will this apply to the DWS's as well? I assume so but just curious to hear from those with experience and some significant mileage with this tire.
Thx.
Thx.
when I got my DWS last year, the installer set them at the max of the recommended range, and I left it there for better mileage and the fact that I carry my family from time to time. When I went to the dealer for service, which included some TPMS diagnostics, they set the pressures to the minimum of the recommended range.
Long story short (too late, I know), set them anywhere in the recommended range for your car.
This was indeed a very sad day! I'll never get it out of my mind. Good for you.
- Tom
- Tom
I went down from 40PSI to 33PSI fronts for a while. Then I noticed the shoulder wear starting so I freaked out and went to 45PSI front and I intend to leave it there. Max pressure is 51.
They have 20,100 miles so far. They should last 40,000 at the current rate.
I'd probably start with 32 all around and make sure to rotate front to back every 5-6k miles and you should see pretty even wear since you're 4matic.
Driving technique plays a part, as does inflation. I get almost flat wear on my fronts with the right tyres, right pressures & driving technique. No shoulder ripping, cupping & feathering at all. If you drive badly your front tyres will show it on a W203. If you adopt a technique that tries to induce some oversteer i.e. into the corner cleanly & swiftly - maybe a minor flick, allowing the suspension to settle, maintain high mid corner speed & accelerate out is best. If you brake late, run in deep & swerve across the apex of the corner you will chew up the front shoulders. Any time that entry speed is too high & the car wants to understeer at the limit will chew shoulder. Controlled in, maintain mid corner speed, fast out is correct & the quickest too. You are not scrubbing off energy.
center wear is also caused by running tires on a rim that is not wide enough. It pulls the tire in at the rim, and that forces the tread to bow out, causing excessive center wear.
I had a FWD 2002 Passat and it was great in snow. Don't drive like an @ss and with a set of DWS you'll be able to go through anything in a 4Motion Passat until the snow is so deep it floats your vehicle (been there, done that, in a 4x4
). Just remember that 4/all wheel drive does not help you turn or stop in snow. Duh?
