- Mercedes-Benz C-Class: Why is My Car Leaking Oil?
Guide to diagnose trouble and recommended solutions
Browse all: Engine Diagnostics
LEAK FROM TRANSMISSION OIL PAN...IS IT MY TRANSMISSION????
Thanx to all that reply
Yangoub
yangoub
Thanx
yangoub
Your mechanic does not seem to be up to date with Mercedes parts and procedures, which may be a bad choice to have things done. The lifetime lasting fluids are not and the ATF should be changed every 39,000 miles -flushing procedure-, requiring either the know-how from "stickies" or the pro equipment and SDS. There is quite a bit of illustrated and well made descriptions of this procedures in this forum.
Checkout installuniversity.com for a how to on replacing it.
But take it from someone thats done it.
Pay close attention to the orientation of the plug.
Getting the new one lined, and not bending any pins is crucial.
Bending one pin, and arrrrgh!
I know that when I put the male piece into the new spacer/connector piece and pulled it out again, the bottom of that male socket was drenched with oil. But part of me thinks it really should be dry in the bottom of that socket and that something else is wrong.
Hard to say if it would get wet in the install process.
Make sure you didn't bung up the orings when you pushed it in.
he said his pan was leaking not the plug. When changing out the gasket please clean the pan very very clean even use a brake fluid cleaner. On the pan there are 4 tabs around it when putting the new gasket in make sure all the tabs line up. I didn't know about this thats why i had to redo the job yesterday. I have no more leaks.. Please make sure the bolts on the pan are not over torqued!! the pan gasket doesn't like to be torqued to tightly! 71 INCH foot pounds 8 NM is what it should be. I changed out that plug as well but mine wasn't leaking. Mine was leaking pretty good around the gasket.
I went to napa and bought the kit filter and gasket.. Looking at the gasket vs mercedes OEM one i just bought. Mercedes fits more snug and stopped the leaking.. Now that ive had so many issues with NON mercedes parts i will stop buying cheap *** parts.
As someone stated installuniversity.com is a great place for information.
http://www.harborfreight.com/transmi...ger-93019.html
Thanx
yangoub
I was also confused about this when I first purchased my C240 and was given mixed responses when asking about it at indy mechanics and this forum.
I was finally convinced when pcy and Glyn (well-respected members of these forums) and the service guy (that I don't personally know) at my local stealership confirmed that it must be done every 39,000 miles. I then proceeded to get this done and my baby now drives like she just came off the lot.
This may also be the reason that you are now having these issues, because proper maintenance on your transmission was not performed.
Best of luck in getting it sorted out.
The problem for me was that the fluid level was so high (even though front of car was on ramps) that it would pool in that area and really never give me an opportunity to get it dry. I had to drain about 1/2 a quart out to get the level well below the connector. Then I could dry things off and install the coupler without getting it all oily in the process.
Simple Green will dissolve the goop without etching whatever else it comes into contact with.
