Installed aftermarket sub and now...
BUT, my installer told me that i will only be getting half the bass capacity because the trunk of my 2004 c320 is sealed pretty well from the factory.
My question, where would be a safe place to drill vent holes if anywhere i was thinking where the skiboot is supposed to be (i do not have the ski boot option on my car)
thanks in advance
thanks in advance
Your joking right?? The spot you took your old bose sub woofer out of should be more then plenty.. Get a ported box if you want it louder. I use to have a 12 inch l7.. But i removed my subs now... would rather listen to my exhaust then thumping
Leave the trunk well alone. You don't want any more ventilation or you will never balance the system.
If you want a ghetto blaster well that's different
thanks in advance
As for boxes I prefer sealed but with a divider in the middle for best result. Never been a fan of ported boxes.
edit: go for 0 gauge wiring.. also a little more expensive, but the power output will also increase.
Last edited by Luke_Geezy; Sep 30, 2010 at 02:02 AM. Reason: more info on subject added
In true high-end audio applications, sealed enclosures can provide tighter more controlled & natural bass e.g. Velodyne with no chance of air "chuffing" in the port.
Ported enclosures such as JL Audio make (slot port for cars) are just fine but the port requires to be properly designed to ensure correct phase at the port opening with the woofer cone face. Back yard sub enclosures seldom get this right if ever.
So - if you are going for a ported design make sure you buy the entire sub & enclosure assembly from a reputable manufacturer like JL Audio that have done their homework on the enclosure port design. No homemade boxes/enclosures.
Note that as with Velodyne - All JL Audio's excellent high-end subs are sealed enclosure for a good reason. Only Paradigm & B&W have achieved top class ported designs. That said I'm aware of air chuffing in the B&W's dimpled port at high SPL's
KEEP IN MIND this will only work for putting a sub and amp into your existing audio system
