Trunk randomly opens.
Old Oct 1, 2010 | 11:22 AM
EuroTech430's Avatar
2003 Mercedes CLK500
Ok, so this question is for my shop because were all stumped and are running out of options. We have a C240 here and the trunk will pop open all on its own, while driving, stopped, sitting outside locked, any time. And conveniently when the trunk opens, the alarm goes off. We changed out the rear SAM with a known good one, unplugged the trunk latch itself, but the relay still clicks telling us its still getting signal. The last thing we can think of is the EIS module but we dont want to change that out unless were sure thats the issue.
Any ideas???
Old Oct 1, 2010 | 10:59 PM
Glyn M Ruck's Avatar
Super Moderator
These are awful problems to diagnose. It could be the EIS.
Disconnect the drivers door trunk switch & see if this helps. The switches sometimes fail & short/contact intermittently.
Disconnect the battery carefully & reconnect to hard reboot all modules. You will then have to resynch things as per the sticky at the head of the forum.
What year is this C240? Early models had very fragile SAM's so be careful disconnecting the battery. Best way is to change out a battery with a quiescent current device to keep the car powered up but then you can't achieve a reboot of the electronics.
Good luck!
Old Oct 1, 2010 | 11:43 PM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
My car won't open the trunk with the car in motion from the drivers side door button. Wouldn't that rule out the door switch as your problem? Hrm.. this is really tricky and would be highly annoying (and dangerous).
Old Oct 2, 2010 | 10:09 AM
ontmiss's Avatar
2007 C280 4matic Avantgarde
I’m really confused now. I can open my trunk when car is in motion. Have not try on hwy yet . I have dodge and trunk will not open if transmission is in any position but P.
Old Oct 2, 2010 | 12:09 PM
Moviela's Avatar
The switch in the key can become dicey after years of use. It can be infused with pocket lint that holds moisture leading to corrosion.
Try taking the battery out of the key to see it the relay still engergizes with the car sitting still. To examine the key you can use a video camera to observe the infrared LED in the end of the key. It it illuminates randomly the key is not working properly. You can also "listen" to the key RF signal with a scanner radio. Different countries have different frequencies, so you need to check the WIS to see where to tune the scanner.
Old Oct 2, 2010 | 12:39 PM
Super Moderator
Sorry - I understood this to mean sans key being anywhere near the car & it would still happen.
Old Oct 2, 2010 | 12:45 PM
97W202's Avatar
2006 C230 6speed/14 C63
glyn can u pm me
Old Oct 2, 2010 | 12:46 PM
Super Moderator
Matt - Correct - The trunk release should lock out when in motion. My car won't. However some cars will open at any time. Damn Benz inconsistency with programming. This can be set with a Star.
Old Oct 27, 2019 | 11:26 AM
artim808's Avatar
2012 S350 Bluetec 4MATIC; 2011 ML350; 2005 C230k;
Any ideas???
Did you fixed this problem? I have same issue on same car. 2002 C240 and trunk will open on its own. Does someone know what's the root of this issue?
Old Oct 30, 2019 | 02:48 PM
Russell Ormerod's Avatar
not a merc
Unplug drivers door control module and report back!
Old Oct 30, 2019 | 04:26 PM
artim808's Avatar
I don’t think it’s the driver door control module. If the car is locked the driver side button to open trunk is not operational. In other words if the car is locked I’m not able to open trunk with button on driver side door. Also car alarm is going off if the trunk open itself. I inspected the lock and it looks ok. I think The rear sam send false signal to the lock.
Old Nov 1, 2019 | 01:34 PM
not a merc
Means nothing that the button is not operational if the car is locked. I said unplug the DCM not just the switch
