Headunit Swap or Adding Bass: Everything you need to know.
Rating: Thread Rating: 3 votes, 5.00 average.
Old 10-01-2010, 10:54 PM
jreC230's Avatar
08 E63
I have done my fare share of installations for over 10 years so i have gather up all this information to help people out here in the forum. Also to try and stop all the new threads about audio information (probably wont but at least it will be a place to point them to)
Dash Parts
01-04 C.. Single Din (Metra Part #)
http://metradealer.com/api/vfg/view-product/id/99-8710
01-04 C.. Double Din (Metra Part#)
http://metradealer.com/api/vfg/view-product/id/99-8711
01-04 C... Harness (Metra Part#)
http://metradealer.com/api/vfg/view-product/id/71-1784
01-04 C.. Antenna Adapter (Metra Part#)
http://metradealer.com/api/vfg/view-product/id/40-VW12
05 and up C.. Single Din (Scosche Part #)
http://scosche.com/products/productID/548
05 and up C.. Double Din (Scosche Part #)
http://scosche.com/products/productID/1452
05 and up C.. Radio Harness (Scosche Part #)
http://scosche.com/products/productID/691
05 and up C.. Antenna Adapter (Metra Part #)
http://metradealer.com/api/vfg/view-product/id/40-EU10
Speaker Colors
Front:
Left - (-,+) Brn/Green - Green
Right - (-,+) Brn/Orange - Orange
Rear:
Left - (-,+) Brn/Pink - Pink
Right - (-,+) Brn/White - White
Factory Woofer.
(-,+) Purple/Blk - Purple
Steering Wheel Controls
Steering wheel modules retain and can be re-programmed if wished
Vol - UP
Vol - Down
Track - Up
Track - Down
Phone option works too if bluetooth is available
Phone buttons when not in use:
Pick up - Source
Hang up - Mute
PAC-Audio will definitely work on the 01-04 models I have installed it on Charles Coupe.
SWI-CAN - Can Bus adapter
http://pac-audio.com/productDetails....&CategoryID=29
Plus specific radio adapter.
For Eclipse Radios..
For Alpine, Kenwood, Clarion, and JVC Radios
For Pioneer, Sony, Jensen, and Dual
All C-Class Steering Wheel Control Module. This modeule works 100% but may need to update the software so if buying online beware. I have the program and wires. I also have it installed on my 05 and Rolands C as well..
http://metradealer.com/api/vfg/view-product/id/ASWC
Adding Bass with Factory Radio
High to Low Converter:
http://www.pac-audio.com/productDeta...&CategoryID=28
This will use the speaker leads to give you the RCA plugs to add amp.. but will still need to run a remote wire (typically the accesory wire in the ignition switch ir tap to the blck/yellow at cigarette lighter)
High to Low Converter with remote out.
http://www.amazon.com/PAC-TRUNKLOC-A.../dp/B0007VNKZ4
This will use the speaker leads to give you the RCA plugs to add amp and a remote out so no need to tap into cig. lighter or acc in switch
If your in the LA area pm me i can get better deals and can also install for a better price (mods feel free to delete this if its not appropriate)
Hope this helps.
Mods make sticky if you like if not it will be in the search...
Ill add more as I remember...
Old 10-02-2010, 01:34 AM
TemjinX2's Avatar
03 g35 coupe...........02 c32 Sold
very nice write up...this should be sticked.
Old 10-02-2010, 02:59 AM
Moderator Alumni
TruTaing's Avatar
w203 m112
agreed++
Old 10-02-2010, 09:08 AM
OneOfaKindTrini's Avatar
Nike Turbo Shox
Niceeeeee. All the info in one place sweet.
Old 10-02-2010, 08:54 PM
W203E35's Avatar
2006 C350 Sport 6MT
Why did you come to the meet so I could have seen your sexy quads. You finally did it huh? :-)
Old 10-02-2010, 09:58 PM
jreC230's Avatar
08 E63
What meet?? Yeah I finished them 2 weeks ago. I'm happy with them just need to change the buls to match my HID ones.
Old 10-03-2010, 12:32 AM
hanknum's Avatar
'02 C320 Wagon, '78 308 GTS, '06 Highlander Hybrid
Nice write up.
Old 10-03-2010, 05:02 PM
bdgdl08's Avatar
1999 CLK320 (sold), 2007 C230 SS (gone), 2000 Grand Marquis, 2011 CR-Z, stay tuned...
I will need this if I ever do any more audio work. Thanks alot!!!
Old 10-03-2010, 06:56 PM
Super Moderator
Glyn M Ruck's Avatar
Great post
Old 10-03-2010, 10:29 PM
maverik259's Avatar
05 C230K SS (sold), 06 C55 (sold), 08 Yamaha R1 (sold), 16 X5M
wait so the pac-swi doesn't work on 05 w203? at all?
Old 10-03-2010, 11:39 PM
jreC230's Avatar
08 E63
Glad to see its helpful
Old 10-03-2010, 11:41 PM
jreC230's Avatar
08 E63
Originally Posted by Glyn M Ruck
Great post
Old 10-03-2010, 11:46 PM
jreC230's Avatar
08 E63
no the pac units will not work on the 05 and up C class. Only thing I found out it can do is clear codes but no will not work for steering wheel controls.
Sorry for the extra posts. I'm using the mobil version and can't multi quote
Old 10-04-2010, 12:05 AM
maverik259's Avatar
192835-12h83r1f78n1 348thjr-a0sdfkqie1-238...
now that my rant is done. WTF that pisses me off. I spent like $100 on the two items cuz I was told they would work. so how do you purchase that other item in the link above? doesn't give you an option to purchase it. and is anything else required to make it work or just that single unit?
Old 10-04-2010, 12:07 AM
maverik259's Avatar
ok found it for like $45 shipped...just need to know if anything else is required to connect this to my kenwood in my 05 w203...then I guess I need to sell my pac-swi can things... FML
Old 10-04-2010, 12:13 AM
maverik259's Avatar
hey jre do you have the wiring diagram to know which wires need to be connected to which wires on the unit? and was it able to auto-detect and calibrate or did you have to do it manually?
Old 10-04-2010, 12:22 AM
jreC230's Avatar
08 E63
No that part should do the trick. Downfall of buying online is that the software may not be up to date which can be a problem.
As per ur PAC parts don't be upset I got some in my stash as well.
Old 10-04-2010, 12:27 AM
jreC230's Avatar
08 E63
Wiring diagram can be accessed online at their website. Also it may come in the package. As for programming I did both just to make sure.
Old 10-04-2010, 12:29 AM
maverik259's Avatar
i couldnt find it on there site...I'll look again.
Old 10-04-2010, 12:31 AM
maverik259's Avatar
ya i looked again nowhere did i find anything about wiring diagrams etc for that product...
Old 10-04-2010, 12:33 AM
maverik259's Avatar
just ordered from amazon for 42. shipped be here wednesday...goal is to install sometime this week depending on this weeks schedule...
Old 10-04-2010, 12:36 AM
jreC230's Avatar
08 E63
http://www.axxessinterface.com/steering_wheel_control_new.aspx
Just fill in the info to get the info you need.
Congrats! You won't regret it. Hopefully it comes with the latest updates so it works with your unit
Where are you located? I can't see locatins on the mobile site.
Old 10-04-2010, 12:45 AM
maverik259's Avatar
maryland is where I'm having it shipped.
Old 10-04-2010, 12:48 AM
maverik259's Avatar
awesome man. ya makes sense I was on the site that you gave in the first post...this looks easy enough...
Old 10-04-2010, 12:50 AM
jreC230's Avatar
08 E63
oh snap.... K crossing my fingers so your unit comes with the latest software.
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
Quick Reply: Headunit Swap or Adding Bass: Everything you need to know.
