2005 c230 kompressor tstat
Old Oct 5, 2010 | 02:39 PM
winterr27's Avatar
anyone got some diy instructions on replacing the tstat in the 05 c230 kompressor? coolant temp below regulating temp is the code!
Old Oct 5, 2010 | 04:10 PM
Glyn M Ruck's Avatar
Super Moderator
P 0128
You don't need a DIY - it's dead simple if you have a set of reverse Torx sockets. See 56
90 deg C Thermostat is P/N A2712000015 for very cold weather
87 deg C Thermostat P/N is A2712030375 for normal conditions
Please feel free to ask questions.
Old Oct 5, 2010 | 06:30 PM
Utahkompressor's Avatar
W124, W203, W204, W251
Very easy...only took me 15 min to change!
Just take 2 bolts out(no.77 in Glyn's diagram)...pull it straight out and that's it!
Old Oct 6, 2010 | 07:39 AM
Super Moderator
+1
Old Oct 20, 2010 | 03:04 PM
maverik259's Avatar
05 C230K SS (sold), 06 C55 (sold), 08 Yamaha R1 (sold), 16 X5M
sweet i just threw this code 2 days ago. Glad to know this is kinda cheap compared to the v6 version which is nearly 100
Old Oct 20, 2010 | 03:08 PM
maverik259's Avatar
of course i live in md now and they only have the extremely cold version and im moving to florida in 2 weeks...haha i dont want the really cold one
Old Oct 20, 2010 | 03:12 PM
maverik259's Avatar
actually neither does the Atlanta mb parts place. Looks like the only one really available is the higher temp one.
Old Nov 19, 2010 | 10:18 AM
upxtech's Avatar
2004 C230 Kompressor
I just ordered a 2712000015 Wahler thermostat to correct a P0128 that I got this morning. I've been reviewing the DIYs, but this is the first that doesn't mention draining the radiator. Is it true that it's just the two screws? Or do I still need to drain some of the fluid out?
Old Nov 19, 2010 | 07:08 PM
You don't have to drain it, unless you want to fulsh the radiator.
Old Feb 16, 2011 | 06:30 AM
slammer111's Avatar
2003 C230K Coupe Orion Blue
Okay, I just ordered off RM European. Got the same failure.
The only version available now is 90C, and the part # is now 271-203-05-75.
Why they made 2 versions with a (tiny imo) 3C difference is completely beyond me. That's probably why they eliminated the 87C version.
Old Feb 18, 2011 | 04:31 AM
slammer111's Avatar
Okay, I just did the repair on the M271. It's not *that* easy.
The 1st pic shows the piece you want to remove (dead centre of the picture). You can see the 2 bolts as well.
The 2nd pic shows the assembly after you pull it out. The thermostat is at the end of the hose. Turns out I had a 90C one put in at the factory. (I'm in Canada). Note where the gaskets are! There are TWO.
Sticking points:
1. You need a 3" extension on top of the E10 inverted Torx bit. I that the middle section of that part (where the hose connects to) got in the way of my ratchet head. Hence the extension.
2. Because of the extension, the intake hose is now in the way. Remove the end of the hose that connects to the airbox (2 clips up top, 1 clip at bottom), and also the big ring-shaped clip at the middle of the hose! I didn't do the ring clip, and snapped (unraveled) my intake tube by bending it a bit too much. This would've been avoided had I also undone the middle clip and given myself the extra few cm of space! Ugh. Time to get some Krazy glue.
3. Coolant WILL gush (glug) out. I thought it'd just be a little bit, but basically the spare reservoir emptied itself. I have no idea how much I lost, so it's time to make a trip to the dealership and also pick up some distilled water. My guess would be 1-2L.
Attached Thumbnails 2005 c230 kompressor tstat-dscn1612-2-.jpg   2005 c230 kompressor tstat-dscn1615-1-.jpg
Old Feb 18, 2011 | 10:08 AM
pcy's Avatar
pcy
'14 ML350, '13 C220 CDI, '07 C280, '98 ML320
if you've used flexible ratchet, I think, you'd been able to remove the thermostat without having to use the extension or have to remove that large intake pipe.
Old Apr 19, 2012 | 08:40 PM
CoupeCrazy03's Avatar
2003 C230 Kompressor Coupe, 2003 E320, 2003 Chevy Corvette Z06
Bookmarked! Thanks guys
Old Apr 19, 2012 | 11:07 PM
JcbyFong's Avatar
bmw
Old Apr 20, 2012 | 01:03 AM
Is it necessary?
Old Apr 26, 2012 | 09:36 PM
Freaking classic. . . I broke a tab on the pipe # 65 on the diagram which was holding onto the thermostat. It was tough pulling the actual thermostat out so be weary when tugging on that thing. I got it off but now I gotta order a new A271 200 1256
