C240 subwoofer install pictorial
Old Oct 23, 2010 | 08:46 PM
Wardsweb's Avatar
'11 SL550 - '08 ML350
I wanted more musical quality and not so much slam in your face. I started with a pair of MTX 12" shallow subwoofers (TT6512) and a Sound Storm Labs EV2.1000 amplifier. I keep my trunk space, have plenty of control and its cost effective.
Old Oct 23, 2010 | 08:48 PM
Wardsweb's Avatar
I contructed the sub box out of MDF. It is built to fit between the fender well braces, follow the slope of the trunk floor, angle of the back seat and still meet the recommended .75 cu ft per sub.
Old Oct 23, 2010 | 08:49 PM
Wardsweb's Avatar
I used PL Premium polyurethane adhesive and my nail gun to build the box.
Old Oct 23, 2010 | 08:50 PM
Wardsweb's Avatar
I cut the face with a circle jig on my rounter.
Old Oct 23, 2010 | 08:51 PM
Wardsweb's Avatar
Subs installed, wired and the box painted with some texture paint.
Old Oct 23, 2010 | 08:52 PM
Wardsweb's Avatar
Pull out the back seat.
Wardsweb's Avatar
Remove the factory subwoofer.
Old Oct 23, 2010 | 08:53 PM
Wardsweb's Avatar
Install the amplifer with rubber isolators to aid in vibration control and better air circulation.
Old Oct 23, 2010 | 08:54 PM
Wardsweb's Avatar
Get the power, ground and trigger (from #7 trunk fuse panel) wired.
Wardsweb's Avatar
route the power wire through the floor channel.
Old Oct 23, 2010 | 08:56 PM
Wardsweb's Avatar
Run the power wire through the firewall on the right side of the passenger footwell. I pushed one of the plastic plugs through so the wire would fit.
Old Oct 23, 2010 | 08:57 PM
Wardsweb's Avatar
Pulled power direct from the battery. I left the stock cable in place and just used a ring terminal and another nut to hold it.
Wardsweb's Avatar
Factory subwoofer signal feeds the amp.
Old Oct 23, 2010 | 08:58 PM
Wardsweb's Avatar
Completed the wiring. It is grounded on the factory ground lug on the right fender well.
Old Oct 23, 2010 | 08:59 PM
Wardsweb's Avatar
When tucked up and out of the way, there is still plenty of trunk space.
Old Oct 23, 2010 | 09:00 PM
Outkasted24's Avatar
Correction, Drove An '05 C230 Kompressor SS
Nice Job!!
Wardsweb's Avatar
All done, clean and neat. I still need to fine tune the settings, but so far I like it.
Old Oct 23, 2010 | 09:23 PM
TemjinX2's Avatar
03 g35 coupe...........02 c32 Sold
thats a very clean install
Old Oct 23, 2010 | 09:34 PM
M-bENZ's Avatar
Corrolla
How did you get signal for the amp ? is it from the factory one ? I thought we have to use the PAC ?
Andy
Old Oct 23, 2010 | 09:58 PM
Wardsweb's Avatar
Andy
The factory subwoofer is fed with a full range signal and uses built in low pass filters to achieve the low bass. See the pic. The caps and inductors form a simple low pass filter.
My amplifer has built in high level inputs, so I can just use the factory signal feed that used to go to the factory sub.
Old Oct 23, 2010 | 10:08 PM
Wardsweb's Avatar
This picture shows the subwoofer wiring color code.
Old Oct 23, 2010 | 10:13 PM
M-bENZ's Avatar
Corrolla
Ic but what if I get one of these basslink how do i get the signal to this ? not sure your familiar with this kind of sub and amp built in.
http://www.amazon.com/Infinity-Bassl...7778255&sr=8-1
Andy
Old Oct 23, 2010 | 10:35 PM
I_C_Class's Avatar
W204 C350 4matic Coupe, W203 C320 4matic, W212 E550 4matic
Holy cow! I would never be able to do that lol
:thumbsup:
Old Oct 23, 2010 | 10:39 PM
Wardsweb's Avatar
Andy
The basslink can take a high level speaker input. Just feed it the OEM non-Bose sub signal.
Old Oct 23, 2010 | 11:10 PM
M-bENZ's Avatar
Corrolla
so u telling me that just kinda take my stock sub out and feed direct to the basslink without modify anything ? and how about the "control" wire ? to the cigarette outlet maybe ?
Andy
