O M G!!!! So PISSED pictures Transmission! sad
Old Nov 14, 2010 | 03:08 PM
Xhale707's Avatar
C320 2002
Originally Posted by Glyn M Ruck
There is a tinge of red in that fluid.
I wonder where the aluminium is coming from? Must be the valve body???
It beats me?? it can't be shavings from the gears? Or shavings from the case. If you look at the ones on my fingers you can see lines.. or ridges
Old Nov 14, 2010 | 04:34 PM
samaritrey's Avatar
Super Moderator
THE C350
i am so going to check my pan in a few weeks when i get the fluid changed again that would make me cry.
Old Nov 14, 2010 | 09:36 PM
Xhale707's Avatar
C320 2002
I will do another change of 4l and filter gasket next week. because for some reason this new one i got is leaking
Old Nov 15, 2010 | 04:55 AM
Glyn M Ruck's Avatar
Super Moderator
You have to clean the pan to transmission casing area very carefully & make sure the gasket is spotlessly clean.
Old Nov 15, 2010 | 07:43 AM
Xhale707's Avatar
C320 2002
I did just didn't use a spray or anything like that.. maybe there is a little bit of dirt or something.. I will re change the filter and gasket around thanksgiving. I won't be driving to much due to it leakin a little bit
Old Nov 15, 2010 | 10:13 AM
fookoo303's Avatar
2003 c240
did you tighten the bolts in the correct order?
Old Nov 15, 2010 | 10:16 AM
  #32
Crna Mechka's Avatar
12 E350 4Matic Sport
I feel your pain xhale...had the trans from my last car, Jetta 1.8T completely crap out, DOA, it was an unreal moment.
Really hope you get it resolved without having to drop $5k on a new trans, that's how much it would have cost me if it wasn't for ins.
I wish you the best of luck man.
Old Nov 15, 2010 | 10:22 AM
  #33
Xhale707's Avatar
C320 2002
Yeah i may loosen and re tighten if that does anything. I wanna get my resonator deleted today but i feel it being pointless lol
Old Nov 15, 2010 | 10:33 AM
  #34
W203E35's Avatar
2006 C350 Sport 6MT
Maybe incorrect torque? I wish I could help but I have no knowledge with the 722.6. Hope this documents helps
Old Nov 15, 2010 | 10:38 AM
  #35
fookoo303's Avatar
2003 c240
it might help. Just make sure your ordering is correct. i also do my torquing in stages, but not sure if its necessary. I wish i could tell you the exact order but i cant remember if its inside to outside or outside to inside, or a variation of the two.
Old Nov 15, 2010 | 10:43 AM
  #36
Xhale707's Avatar
C320 2002
It's
Now its 8NM which is about 71 inch pounds 5.9 ftlb and my torque wrench only goes from 20ftlb to 150 blah maybe i should go buy another torque wrench.
Old Nov 15, 2010 | 10:50 AM
  #37
Xhale707's Avatar
C320 2002
Going to go to harbor freight to buy another torque wrench brb
Old Nov 15, 2010 | 11:51 AM
  #38
fookoo303's Avatar
2003 c240
ok good luck man, hope it's as simple as that.
Old Nov 15, 2010 | 12:32 PM
  #39
TruTaing's Avatar
Moderator Alumni
w203 m112
wow. that is terrifying.
Old Nov 15, 2010 | 01:30 PM
  #40
Xhale707's Avatar
C320 2002
Yeah i drove the car to harbor freight everything went fine shifting etc.. i always leave that place happy
Old Dec 10, 2010 | 10:16 PM
  #41
splinter's Avatar
Super Moderator
GMC - Miata - Trek - P-Car
Is your transmission still transmitting?
Old Dec 11, 2010 | 02:31 AM
  #42
Xhale707's Avatar
C320 2002
Um lol yeah i still drive my car like a race car.. shifts perfectly.. I did another pan flush to check if there was anymore shavings and there was none.. Funny thing is after fluid change car seems to pull harder now.
I don't have any leaks anymore for now that is.. Car handles so differently i don't know if its the cold.. But the car handles amazing feels so heavy..
My girl even said the car drives differently in a good way.. Seems to stick to the road now
