Battery Alternator Visit Workshop, Battery Just Replaced Yesterday...
Old 11-14-2010, 02:21 PM
Super Moderator
nlpamg's Avatar
2019 GT3 RS, 2017 M3 30 Jahre
Hey guys,
I had service B performed on the w203 yesterday and I had them replace the battery as well. The battery was replaced 3 years ago at 45k miles and now the car is at 94k miles.
I had them replace the battery b/c during starts in the morning, the car would shut down the radio, a/c, etc. Intermittently, I would get the "Battery Alternator Visit Workshop" error.
I took it to the shop a year ago and told them this and they tested out the battery and it appeared that it was getting proper voltage.
But, this morning, I got the error message 4 times straight, consistently. It usually happens in the mornings when the car and the temperature (this is So. Cal.) is relatively cold (which is below 60 degrees).
I took the car on a very short drive and then the car for a moment said ESP unavailable and shut off the radio, but after a few seconds everything came back on.
So, I realized that I needed to check it out in dyno mode... I put the car into dyno mode and took the car for a pretty hard drive just to test it out:
When I started the car in dyno mode it read 12.5-12.6V.
At idle it jumped up to 13.4-13.5V.
Under acceleration and highway speeds, it was at 14.1-14.2V.
All those numbers seem normal. I guess my alternator is going.... Any thoughts?
Thanks.
Old 11-14-2010, 09:14 PM
contact148's Avatar
2003 c240 4matic wagon
try same thing dyno mode at idle
note voltage then turn on the headlights it should drop but come back up then the heater, seats, defroster ect load up all power items and see if the voltage comes back up
seems kinda low.....
Old 11-14-2010, 09:24 PM
havoc_vulture's Avatar
'05 c230 Kompressor SS Mistress
I had the same problem a couple months ago.
I replaced my alternator and the problem was solved.
That was my experience with my alternator. Same signs as you have listed there except that I did have some under-voltage on two occasions that i put a volt meter on it. Good luck.
Old 11-14-2010, 10:18 PM
Xhale707's Avatar
C320 2002
If a malfunction occurs in the charging circuit, do not immediately assume that the alternator is causing the problem first check the following items.
1. The battery cables where they connect to the battery. Make sure the connections are CLEAN and TIGHT.
2. Inspect the external alternator wiring and connections.
3. Check the drive belt condition and tension.
4. Check alternator mounting bolts for tightness
5. Run the engine and check alternator for abnormal noise.
6. use a voltmeter, check the battery voltage with the engine off. It should be at least 12.6 with a fully charged battery.
7. Start the engine and check the battery voltage again it should be 14.22 No more than 15.
If the indicated voltage reading is less or more than the specified charging voltage, have the charging system checked. The voltage regulator sometimes tends to go out. At that time just replace the whole unit
But OEM battery last's a very long time 7 years or longer.
If it's not the alternator other choices are your fuel filter when was that replaced?
Dirty or clogged Fuel injectors can cause this 2 try techron from chevron.
Also Defective spark plugs along with defective coolant temperature sensor.
But im 99.8% its the alternator or the voltage regulator.
boski53 (05-12-2018)
Old 11-14-2010, 11:32 PM
Super Moderator
splinter's Avatar
GMC - Miata - Trek - P-Car
Originally Posted by Xhale707
..Dirty or clogged Fuel injectors can cause this 2 try techron from chevron..
Almost certain nlpamg uses Techron with some regularity.
Failure to do so will not prompt a "Battery Alternator Visit Workshop" warning in the MFD.
Its replacement battery is OE-specification, yes?
Our little C’s have unusually high ampere-hour requirements, not to mention being particularly finicky with all things electrical.
Had a high-end aftermarket replacement fail (in the GMC) within a week of installation. Replaced under warranty, but it’s always a PITA to call AAA at 05:30!
Don’t want to hear of you suffering a similar fate.
Curious yours registers 12.5 volts before starting and 14+ while underway; exactly as it should. I’d first suspect a marginal ground or faulty connection in the circuit, but I’m no EE. Telling that it’s throwing errors the day after yet another battery installation. Hard to pinpoint without proper DVM or SDS diagnosis, though.
Respectfully suggest load testing not only that new battery, but also its alternator.
The alternator contains diodes and a rectifier that can manifest intermittent weirdness, in addition to normally-occurring brush and armature wear.
PN is 271 154 08 02 88. ~$350.
Old 11-15-2010, 01:37 AM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
Phil my 2005 now has 95,200 miles and is on the original battery. Here are my numbers:
Pre-start, cold: 12.2V
Idle: 13.4-13.6V
Underway: 14.1-14.2V
Those look really similar to your numbers. I have never had that warning or any of those symptoms, ever.
Old 11-15-2010, 04:13 AM
Super Moderator
Glyn M Ruck's Avatar
Phil - Those numbers are OK. As splinter says could be a wonky diode in the regulator/alternator but they usually work or don't.
Step one is having the battery load tested & check all connections especially ground/earth.
What codes is she storing?
Make sure you have a 100Ah battery
Old 11-15-2010, 07:27 PM
Super Moderator
nlpamg's Avatar
Thanks for all the help, guys!
I can't read any codes on it, and they didn't tell me if there were any codes on it when they did the Service.
They got the battery from the dealership and I would hope that it was installed properly.
Apparently, this morning, the car did it again and it felt like it was going to die. Then after 2 restarts, it was working fine.
The engine is still pulling strong. It's just the damn electrical.
I guess I'm going to just have to bite the bullet and put in a new alternator.
Are there any other parts that are worth replacing while he's in there? They said that it was a pain to get to the alternator on the M271...
Thanks.
Old 11-15-2010, 07:53 PM
mleskovar's Avatar
'17 Jaguar XF
suggestion.....
Before replacing the alternator check your battery at various times to see if it's being drained...like from a seat module. Your idea of "relatively cold" Assuming you have a DVM available....
1. Check battery voltage after you stop following a good drive that would charge up the battery....should be >12.45 Volts (75% charge)
2. Check battery voltage the next morning before starting....did it drop at all?
Old 11-15-2010, 09:29 PM
MBworld Guru
FrankW's Avatar
white and whiter
your alternator went dead. lol
Old 11-16-2010, 10:54 PM
Super Moderator
nlpamg's Avatar
so I told my shop that I found an alternator for $370 on RMEuropean and they also found the same thing for $10 less (it was a Bosch alternator).
they put it on and the car was doing the same thing. they checked on STAR and said that the car didn't take the alternator and that they have to replace the Bosch alternator they put in with a Valeo one from the dealer.
while they're at it, I'm having them replace the belt as well...
Old 11-16-2010, 11:28 PM
Again same thing as me.
except i did not replace my belt
Old 11-17-2010, 05:03 AM
Super Moderator
That's wierd - The Bosch & Valeo alternators should be interchangeable. Has the Valeo alternator cured the problem?
Old 11-17-2010, 10:01 AM
Once i installed the Valeo it was fine and has been fine since for me.
Old 11-17-2010, 03:41 PM
LILBENZ230's Avatar
I'll make a note of this and only buy the Valeo if/when the time comes. My car doesn't show any signs of alternator trouble @ 95,500. Even the original battery seems okay.
Old 11-17-2010, 06:34 PM
eesjunin's Avatar
Nowhere ...Fast
replaced my alternator with Duralast with no problems...at fraction of the costs you are mentioning
Lifetime warranty!
Bosch oly comes with 2 year
Old 11-17-2010, 07:50 PM
seagel1000's Avatar
05 C230 Kompressor
Incase anyone is wondering, this is the Valeo alternator i purchased. Lmtd. life time warranty on the part.
http://www.napaonline.com/Search/Det...+50044+2044109
My local NAPA had it (located on Washington Blvd & Eastern Ave in Commerce, CA) right around the corner from the Commerce Casino off the 5 freeway exiting Washington.
It was $274 and change OTD. With core refund it is coming out to $198. That is fairly low if you ask me!
Old 11-18-2010, 12:38 AM
tijn's Avatar
White w203 C200K Elegance
had the same problem about 1 year ago. replaced alternator problem solved.
Old 11-25-2010, 08:27 PM
drho2004's Avatar
2005 C230 SS
man oh man...ive been having the same issue with my MY2005 C230k with 71k miles...on cold mornings (so.cal here) i get the no ESP warning followed by the Alternator warning, but all works well after that. Even my cruise control is fine. But it seems its my altenator going out here. dammit..
how difficult is it to do it on own? or is this something better left for a shop/dealer?
Old 11-25-2010, 08:48 PM
i can do mine in like an hour and a half
good luck
not too hard actually
the alternator comes out from the top
Old 11-25-2010, 10:32 PM
ammar_rage's Avatar
C230 KOMPRESSOR (2003)
I had started another post with the similar problem...my voltages are same as Phil's, if there is a problem with the alternator then there is a very good chance that the battery would prolly not get fully charged and if we are able to see the voltages around 13.5 after a good drive hints that the alternator might very well be ok...now as i do if you experience that your voltage is below 12 v the next morning, then to me it seems like the battery is just not holding the charge. My battery is over 7 years old now.
Old 11-26-2010, 10:33 AM
seagel1000's Avatar
05 C230 Kompressor
2 hours tops with all your tools ready.
Follow this thread for pics and steps/tools needed.
https://mbworld.org/forums/c-class-w...8l-c230-2.html
Old 01-04-2011, 03:55 PM
drho2004's Avatar
2005 C230 SS
thanks for the reply...now this is getting weird..i keep getting all kinds of weird electrical issues..i.e HUD tells me that my left blinker mirror is out, but..i physically check and its working just fine, tells me that my coolant is low i check, not its not. it does this every other day. it seems the ecu is acting up, giving me all these errors. question, how do i 'reset' the computer? unplugging the battery then reconnecting? does the dealer need to 'reformat and re-install' the software ? thanks!
Old 01-04-2011, 05:50 PM
bigspender101's Avatar
2003 c230k
Hey Havoc, Do you have a write up on how to replace the alternator? Ive searched and haven't come up with a good one.....
Old 08-12-2011, 10:10 AM
JTB007's Avatar
05 C230 Kompressor
I went to the Napa site and the don't carry the Valeo for my '05 C230 Kompressor...any suggestions fellas??
Quick Reply: Battery Alternator Visit Workshop, Battery Just Replaced Yesterday...
