I can't bleed brakes!
Old Nov 14, 2010 | 05:23 PM
zerocover's Avatar
2007 C280 4Matic
I went out and bought a motive power bleeder, and 2 quarts of MB fluid.
I turkey bastered the old fluid out of the master cylinder, hooked up the motive bleeder after filling it and the master cylinder with fluid, then pressurized the system to 10 psi. I did the passenger rear caliper first. I attached the clear hose, opened the bleeder and let it run. Everything went smooth.
After that I tried doing the driver side rear caliper and for the life of me I can't get the bubbles to stop, I've gone though .5 liters of fluid and I still have tiny bubbles coming out of the clear line. I'm doing everything the same. Help! What should I do differently?
TL;DR: How do I get all the air out of the brake line properly?
Old Nov 14, 2010 | 06:39 PM
OneOfaKindTrini's Avatar
Nike Turbo Shox
Reverse bleeding.
Old Nov 14, 2010 | 08:26 PM
contact148's Avatar
2003 c240 4matic wagon
air getting into hose attached to caliper
Old Nov 14, 2010 | 09:02 PM
Popo's Avatar
2007 GL450 2005 C55 2002 C32 sold 2001 ML320 sold
+1 - try re-attaching the hose or sealing with grease / petroleum jelly
Old Nov 14, 2010 | 11:13 PM
ncmudbug's Avatar
2005 C230K, 2019 Honda CR-V, '74 Lotus Europa
Did you loosen the bleed screw too much? Just loosen it enough to get the fluid to flow.
Another possibility is that an upstream fitting is loose or there some damage to the line or hose. You didn't mention replacing hoses or any damage so this seems unlikely.
Old Nov 15, 2010 | 08:17 AM
zerocover's Avatar
2007 C280 4Matic
This makes no sense to me. I've pressurized the system so fluid should flow out from every and all areas. I should have leaks with fluid coming out not air going in.
My theory was that when I pressurized the fluid I dissolved air into the fluid and when the fluid came out the other size the lower pressure caused the bubbles to form. The only way I can fix that is with a vacuum bleeder. Which I hope isn't the case because it means I've bought a useless brake bleeder. As other people have had success with this system I hope that's not the case.
Old Nov 15, 2010 | 08:36 AM
ncmudbug's Avatar
You are probably right if you ALWAYS maintain positive pressure. If not, it remains a possibility. I've seen it happen with the old two-man pump and bleed method. If you always maintain positive pressure, then it sounds like you have a leak somewhere.
I bought a Motive bleeder too, but I haven't used it yet so I'm a veteran of somebody pumping the brakes and opening the bleed screw.
Old Nov 15, 2010 | 11:09 AM
e1000's Avatar
a quarter mile at a time
Try the two suggestions above. Re-attach the bleeder hose and only loosen the bleeder screw just enough for fluid to start flowing.
Old Nov 15, 2010 | 11:23 AM
Glyn M Ruck's Avatar
Super Moderator
Try just cracking the bleed screw open as e says.
Also try bleeding the brakes with the car idling & the ABS system active. See if this changes the pattern of what you are seeing.
