Short and Simple K&N
Car was starving for air on the dyno.
Was loosing 10whp
Gave the K&N a shot and I noticed a significant different.
Won't really know how much I gained ever.
Paid $87.00 dollars out the door.
Car use to squeak off the line but now breaks traction (but I might have gained down low but lost more up top).
Haven't done a freeway run to see how up top is.
Honest opinion is if your car is tuned then you might benefit from a higher flowing filter but if your car is stock then it might not do much or even anything.
Just hope it doesn't kill my MAF
Was loosing 10whp
I was scared of getting those filters.. did you ever think about greens?
Also ppl leave the filters out for a bit to dry them out
I just replaced my green filter (completely disintegrated in the housing somehow) with a K&N, which didn't feel over-oiled. Then Sunday, I replaced the MAF, which had been throwing codes, probably because the green filter had been dead a while. So it'll be interesting to see if the MAF throws the code again (P0712) after a while, due to the K&N.
1) I was curious about the oiling issue; I've had a CAI w/a K&N in my crx for about 8 years now without problem
2) I do like being able to use it again and again, since I've already got the oil and cleaner for my CAI
3) Since my car is about as modded as you can get for the C230 without going to internals, I figured it might benefit my car's breathing a bit
4) With so many people here whining about it, I figure it must be ok
