Phister's car thread
Old Mar 31, 2012 | 07:03 PM
  #1051
hcalvarez's Avatar
2005 C230 Kompressor
looking good phi! like it!
Old Mar 31, 2012 | 07:24 PM
  #1052
phister's Avatar
06 C230 SS 6spd
thanks... I lowered it more its going to look ballin' lol I'll see how low it goes then, if I want to go lower I'll remove the lower perch to lower it more in the rear.
Old Mar 31, 2012 | 08:19 PM
  #1053
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
nice
Old Apr 1, 2012 | 01:04 AM
  #1054
a3i's Avatar
a3i
2005 Mercedes C230
Whoa, thats going to look hot
Old Apr 1, 2012 | 03:55 AM
  #1055
TruTaing's Avatar
Moderator Alumni
w203 m112
Looks good! must lower if you're gonna do ccws justice!
Old Apr 1, 2012 | 08:09 AM
  #1056
phister's Avatar
06 C230 SS 6spd
Lol I didn't let the suspension set when I took the pics. It sits a lot lower.
Old Apr 1, 2012 | 12:38 PM
  #1057
TruTaing's Avatar
Moderator Alumni
w203 m112
purrfeecccttt cant wait to see it all wrapped up! (figured you were lower in all your pix)
Curious: how much did you think you pull the fenders out from the stock?
Old Apr 1, 2012 | 01:58 PM
  #1058
phister's Avatar
06 C230 SS 6spd
shoot I dunno how much I pulled it since I did it once before. But I did at least a good maybe 7-10mm more. I basically dont have the the flat part anymore on the fenders its all arched.
So I got the rear dialed in to my liking. I got bored and put some negative camber on and allowed me to keep the 5mm spacers in the rear so now the rear is at +15 offset now! so i'm going to be running +15 all around now. heres some pics of how the rear ended up.
my dirty car
Old Apr 1, 2012 | 09:12 PM
  #1059
TruTaing's Avatar
Moderator Alumni
w203 m112
oohhh looks perfect back there - its dirty in a good way!
Old Apr 1, 2012 | 11:40 PM
  #1060
phister's Avatar
06 C230 SS 6spd
hahaha thank tru... I have to lower the front now, but I'll do that all once the tires come in so I can see how it looks before I adjust. hopefully the fluted and eccentric bolts come in soon too.
Old Apr 2, 2012 | 06:37 PM
  #1061
glocati's Avatar
2016 GLE 350
Wow ! Congrats. Those are hot. My pants just got shorter. Strong strong work, Phister !
Old Apr 2, 2012 | 11:22 PM
  #1062
phister's Avatar
06 C230 SS 6spd
Thanks man! So I got to change my UPS delivery to will call so I could pick the front tires up in the morning. Then it well be done.
Old Apr 3, 2012 | 01:41 PM
  #1063
a3i's Avatar
a3i
2005 Mercedes C230
Where did you order the fluted and eccentric bolts from?
Old Apr 3, 2012 | 03:23 PM
  #1064
phister's Avatar
06 C230 SS 6spd
rmeuropen.com
I was actually messing with the struts while lowering it more and decided to loosen the bolt where the eccentric bolts are going, the bolt that holds the strut to the hub and found out I can mess with my camber without the eccentric bolts!!! So all you need to do is loosen the 2 bolts that hold the bottom of the strut to the hub and the top bolt that hold the strut as well to the hub. Dont remove the bolts just loosen them some. With them loose you can actually push the upper part of the hub/rotor back and forth, maybe its just my coilovers design, I'll look at my OEM ones and see if it has designed the same way. But with that I can adjust my camber so i just pushed them all the way till the bolt stopped and tightened the bolt down, then tightened the other two down. So now my fronts fit perfectly now and I can lower it even more.
Old Apr 3, 2012 | 07:05 PM
  #1065
phister's Avatar
06 C230 SS 6spd
AND BOMB GOES THE DYNAMITE!
Going to lower the front even more now since I got my front camber going. Thought dropping it 1/2" would do the job but it didnt so gonna drop it another 1/2" it and should look even with the rear.
Old Apr 3, 2012 | 08:08 PM
  #1066
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
looks good
Old Apr 3, 2012 | 08:21 PM
  #1067
phister's Avatar
06 C230 SS 6spd
Thanks frank
Old Apr 3, 2012 | 08:29 PM
  #1068
Midnight Koop's Avatar
CL203
nice! i think i've checked your thread as often as i checked my email waitin for pics. looks sick... my car sits pretty similar to yours in the picture. i've been wanting to lower my front, but need to get something to protect my lip from scraping. maybe i'll get one of those EZ lip garage liners too
Old Apr 3, 2012 | 08:51 PM
  #1069
phister's Avatar
06 C230 SS 6spd
Just get it at Lowes think I listed the parts a few pages back.
Old Apr 3, 2012 | 08:52 PM
  #1070
phister's Avatar
06 C230 SS 6spd
I plan on shoveling gravel once I drop the front more haha
Old Apr 3, 2012 | 09:59 PM
  #1071
glocati's Avatar
2016 GLE 350
Hot damn ! Looks great. Stanced indeed. Pokin'
Old Apr 4, 2012 | 12:37 AM
  #1072
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
i actually raised my car up over the wknd. lol
Old Apr 4, 2012 | 01:11 AM
  #1073
TruTaing's Avatar
Moderator Alumni
w203 m112
Phister - you are the man! CCWs and going to all new lows w/ those COs Great work!
Old Apr 4, 2012 | 06:58 AM
  #1074
phister's Avatar
06 C230 SS 6spd
Lol it just feels too weird riding in stock cars I need to be close to the ground. Even my gfs is250 feels high
Old Apr 4, 2012 | 07:01 AM
  #1075
phister's Avatar
06 C230 SS 6spd
Thanks tru, always have to push the boundaries right?! Got some other exterior and interior mods up my sleeve. Its going to be a fun summer.
