Phister's car thread
Old Sep 8, 2012 | 08:11 AM
  #1301
MBfinatic's Avatar
e36 318i, 2004 sti
Pictures of the Cf chambered intake?
Old Sep 11, 2012 | 01:53 AM
  #1302
phister's Avatar
06 C230 SS 6spd
So I had an eventful day after coming home from work. My lip for some reason was scrapping the road on everything. So when I pulled in my garage and got out my front drive side was flat, lucky i got the full size spare. Ordered my 215/40/18 from tirerack so they'll be in tomorrow or wed. So I go to inspect my tire and the whole inside sidewall is worn down and caused a leak. Upon further inspection I found out that one of my lower strut bolt was missing which loosened the other side and the upper bolt so my camber went way negative causing the upper tire to rub against the strut and spring which made the crazy groove on the side wall. So I had to go buy a bolt to replace the missing one and corrected my camber and torqued everything to spec to make sure it didnt happen again plus I got locking washers as insurance. So guess I'll be going a bit lower now since I got the new tires coming in. I might have to remove my cf lip knowing its going to get abused even more than what it already has endured.
Old Sep 13, 2012 | 07:35 PM
  #1303
phister's Avatar
06 C230 SS 6spd
got my new toy installed. Got an Ark Design MFD-2. can monitor up to 8 things on one screen. Speed, RPM, A/F, Injector cycle %, Water Temp, Oil Pressure, Oil temp, vaccum/boost, and throttle %
can do 1 or 2 analog dials or 1,2,4 or 8 digital. you can even adjust your speed correction if you have different wheels from stock. connects to your OBD plug. I need to buy the sensors for the oil pressure and temp so I can monitor them. also waiting for the monitor stand so its just taped to dash for now
Heres the MFD-2 and snapped some pics of my gold foil wrapped intake and lowered the car a tap when I got new tires. got about 2" of clearance.
heres the digital in 4 monitors. currently running this with a/f, water temp, vaccum, and throttle as my monitors.
Gold wrapped intake (got DEI radiant gold foil tape wrapped around it to keep the heat
way)
heres a look at my clearance with an oil wrench barely fitting underneath
Old Sep 15, 2012 | 03:35 AM
  #1304
tanman430's Avatar
2001 Ml430 | 2003 C32amg
Wow!
Hey Phister what wheels are those on your ride? Those are ****king Sick!!! LOL 8P
Old Sep 15, 2012 | 10:29 AM
  #1305
phister's Avatar
06 C230 SS 6spd
CCW Classics
Old Sep 17, 2012 | 03:54 PM
  #1306
bobbyadeli's Avatar
what carbon fiber front lip do you have? and where did you get it if you dont mind me asking? looks awesome. any fitment issues?
Old Sep 17, 2012 | 06:07 PM
  #1307
TruTaing's Avatar
Moderator Alumni
w203 m112
Interesting intake. No dual intake for both of your naca ducts?
Old Sep 17, 2012 | 06:32 PM
  #1308
phister's Avatar
06 C230 SS 6spd
naw tru, just decided to let one naca duct bring in cool air for the engine and let heat escape.
Old Sep 17, 2012 | 07:34 PM
  #1309
tommy's Avatar
2004 Civic Si. FWD for the Win!
The other is for the cooling of the NOS system, of course.
Old Sep 17, 2012 | 08:32 PM
  #1310
phister's Avatar
06 C230 SS 6spd
lol i really was considering adding a wet nitrous setup to the car. my friend has one sitting at his house i might buy off him. a simple 50-75 shot would be good.
Old Sep 26, 2012 | 07:40 PM
  #1311
C230Kreepin''s Avatar
04' C230K
Hey Phi, I just got my BC coilovers today and I was wondering if yours came with camber plates?
Old Sep 27, 2012 | 12:14 PM
  #1312
TruTaing's Avatar
Moderator Alumni
w203 m112
Doh! I just saw the post about your flat. Sucks to hear! How does one lose one of the lower strut bolts??! I say you go low w/ those 215s up front and leave the lip on so you can protect the bumper some more Maybe you can throw in some of those front adjustable camber bolts to save yourself some tire wear and move your tires away from the strut also.
Old Sep 28, 2012 | 06:16 AM
  #1313
phister's Avatar
06 C230 SS 6spd
dont worry tru I installed my 215/40 already. car sits nice now. Have to admit my lip is all beat to hell on the underside. I put 12mm spacers up front and pushed it out just a hair more to clear things. I might go lower on it but with the shorter sidewall it sits nice now.
Kreepin, no our doesnt come with camber plates. the design our towers wont allow for camber plates.
Old Sep 28, 2012 | 12:03 PM
  #1314
TruTaing's Avatar
Moderator Alumni
w203 m112
woah woah woah. 12mm spacer + 18x9 up front. (mind blown) If that's the case - people could potentially run 18x9.5 w/ enough camber and skinny tires.... crazzzyyy!
Old Sep 28, 2012 | 03:26 PM
  #1315
phister's Avatar
06 C230 SS 6spd
if you really want to pull the hell out of your fenders ya you can fit 18x9.5 lol I've had to have pulled my rears a good 25mm or more and fronts at least 15mm. fixing to order my 3.5" lip from CCW now since I had to buy new tires first.
Old Sep 28, 2012 | 06:16 PM
  #1316
TruTaing's Avatar
Moderator Alumni
w203 m112
Yea, i figured you could fit that 18x9.5 w/ enough rolling. the front fenders are super soft/easy to roll too... Are you rubbing when you go lock to lock? Or did you manage to pull out that pesky windshield wiper res?
Old Sep 28, 2012 | 11:23 PM
  #1317
phister's Avatar
06 C230 SS 6spd
I can go lock to lock with no issues at all. When I took the wiper res out I didn't think it was that involved but I found out there's a cooling coil that goes to the radiator system inside the res. Totally forgot mb does that. The coil runs the length of the reservoir so I'm gonna have to chop the OEM one and then mold it back together
Old Oct 1, 2012 | 02:31 PM
  #1318
Stackaholic's Avatar
damn homie ur car is sick just got to the 53rd page. most pages pix dont work but i just picked up a 07 c280 4 matic last week
Old Oct 1, 2012 | 08:06 PM
  #1319
OneOfaKindTrini's Avatar
Nike Turbo Shox
wasup fellas. phister your car has come a long long way. looks great.
Old Oct 2, 2012 | 12:30 PM
  #1320
Jay_Soprano's Avatar
06 w203 Blk/Blk - 06 w251 slv/blk
Hey Phister - Quick question when u received ur BC.'s did they have the top plate adjuster for camber? Cause I got mine and It didnt
Old Oct 2, 2012 | 01:14 PM
  #1321
tommy's Avatar
So phister, about where you're putting your spare tire........I don't see pictures!!
My Moda rim is now being powdercoated, and will be done on Friday. Then I'll figure out how to mount it in the back of the hatch; will most likely use the D-rings to secure it down somehow.
Old Oct 2, 2012 | 01:42 PM
  #1322
04' C230K
You should read the thread, I literally asked that question a few posts up. I have a question for you though, what W203 did you get those for?
Old Oct 2, 2012 | 01:44 PM
  #1323
06 c230
Old Oct 2, 2012 | 04:10 PM
  #1324
phister's Avatar
06 C230 SS 6spd
sorry tommy, i have them in the normal spare tire spot.
No our cars are designed where it'll be hard to do front camber plates.
also be careful when installing the front because the upper strut mounting hole is oval shaped so you can adjust the camber quite a bit. its designed to use a eccentric bolt so when you install it make sure you dont push the hub in too far or pull it out too far or you'll camber will be off.
Old Oct 3, 2012 | 06:22 PM
  #1325
04' C230K
I don't know why but my coilovers did not come with replacement tie rods. I bought mine for a 2004 mercedes benz C230K SS. Was I jipped? :0
