Constant power in 12V cigarette lighter
If there is one please let me know.
My friend has an Audi A6 that has power in the cigarette lighter even if the car is turned off. But in my C203 -05 it cuts the power when the ignition is of as most cars.
Is there any way to bypass this wiring so it will always give me power even if the car is off?
You'll need to do all the steps in order to remove your radio to get to your wires.
I went to Radio Shack and purchased a $5 cigarette adapter that has a base that can be screwed to another surface. I then opened the interior fuse door (located at the junction of the drivers door and the dash board), mounted the adapter just behind the fuses and just plugged the adapter wire into one of the open fuse slots.
It was only a bit more complicated than what I just typed here. It took about 10 minutes. The biggest time consumer was contorting my fingers to get the adapter behind the frame, then crimping a female wire clamp on to the wire. I then ran the charger wire along some dash seams, to the spot I like on my dash, to provide a very well concealed set up that provides constant power to the phone, key on or off.
Note that I plugged the adapter into a 20 amp fuse and put one leg of the fuse into the slot. (front yellow fuse)
Hope I didn't confuse you to much with my questions
Oh, and I stand corrected. I used a 20 amp fuse.
You would be able to run a short cord to the camera from that fuse box. Otherwise, you would be running a cord all the way from the center console; pretty obvious set up with the cord.
I will post again when it's finished or if I need more help
Happy new year to you all!
Hate to resurrect an old thread, but the images no longer show here. Is it possible for you to post/send a link to the cigarette adapter that you placed behind the fuse box?
