Think blizzaks will do any good in pictured weather?
never owned a set of "snow" tires before...
think the blizzaks could get me out of pictured situation aka 4-6 in of snow? (obviously much better situation on the main roads, but I need to actually get out of the damn parking lot to get there)
tanks gentlemen.... and ladies (Matt, Karo, ND2020)
What kind of tires are you running up front?
Im running Michelin XSE on front
Wife has Sumitomo HTR Z3 on front
I got quoted about $450 for two of the blizzaks with dismount/mount/balance @ authorized retailer (firestone). Road hazard is like an extra $25 a tire (think its worth it? bc im really not thinking so unless someone says otherwise... in case tire is damaged and cant be repaired, I would only be entitled to pay prorate based on how much tread is left, no expiration)
So, considering front tires... think it's good investment for the rear blizzaks to reliably get me out of anywhere from 1-6 (or more?)in of the fluffy stuff in parking lots and side roads??
Thanks!!!!
good to hear from another person who has driven through some snow in their life before! It's a passing phenom here in the midwest. If anything we usually get ICE, which in my experience leaves you eff'ed if you do and eff'ed if you dont
I got quoted about $500 for two of the blizzaks with dismount/mount/balance @ authorized retailer (firestone). Road hazard is like an extra $40 a tire (think its worth it? bc im really not thinking so unless someone says otherwise... in case tire is damaged and cant be repaired, I would only be entitled to pay prorate based on how much tread is left, no expiration)
Thanks!!!!
The blizzaks will definitely get you going but without decent front tires, stopping and handling will be difficult.
With my car being dropped and with continental DWS tires, I still slide coming to a stop if don't brake very very early. Before she drives her car, you should pull into a parking lot or empty street and see if her front tires will stop the car at all from a slow speed.
I recommend that you atleast buy some really cheap winter tires and throw them up front. the cheapest winter tires will be a world of a difference compared to any summer tire.
I can afford to go all around on hers for her safety if I need to, and it sounds like I do. Do you have a all-season tire (like your DWS?) that you can recommend (preferrably carried by Firestone) that we could just put all the way around instead? She doesn't need any of the creature or performance comforts out of a tire that we here would seek.
Likewise I could maybe also do snow tires on her rear and all seasons up front? Either way, Im still listening, thanks brother.
I'll probably get her in a pair of rear blizzak and then buy a pair of firestone's in house off-brand all season tire for her front. If it were me, Id brave the Sumitomo's on the front, but she is notorious for cutting corners sharp, braking late, and generally not paying a damn bit of attention to what the hell she's doing. Perhaps its the woman in her? Maybe maybe?
Summer tires up front...no, no, no...no.
Winter tires are not only for snow and slush removal due to larger cleats, BUT as the weather turns near 40 degrees Fahrenheit, the dynamics of an all-season and especially a summer tire – dramatically change! Near 40 degrees Fahrenheit, a snow tire retains a lot of flex and ability to make contact. It also greatly increases stability on ice, while nothing can truly be efficient or effective on ice – snow tires are the only viable option.
With the w203 – you have the best option in a MTX…use it. IF you need to start in second…if you have to use first to get moving – quickly go into third, keep torque low and feather the clutch. We have never had an issue in Buffalo with our w203 MTX.
We run Cooper Weathermaster ST2.
(PS…get all four tires – it is cheaper than you deductible, and saves time if you wreck…plus your safety, your wife’s safety and the safety of others is more important.)
Then for me, my school is located in a similar situation - parking is at the bottom of an area with uphill either way, one way is 45 deg, the other 40.
My tires are apparently Michelin Pilot Primacy w/ XSE. Pilot Primacy looks to be the OEM tire? Anyway, getting mixed reviews. Some sources say all-season, others say high-performance summer tire for luxury sedans. Either way "XSE" on Michelin's website refers to a silica compound added for greater wet/snow traction. Go figure. I didn't attempt my car today, so maybe I will give it a quick go out in the parking lot here in a few to see what happens. Either way, still going Blizzak on the rear of mine, but may be safe to leave the Pilot's up front. Im leaning towards all-season considering Michelin's website quoted XSE technology for wet and snow traction. what ya think?
Know anything of my pilot primacy with xse? viable for winter?
. And these tire sizes are cheaper as well and wont throw off the speedo since thats what the winter tire size is displayed on the door I think.
Never tried it myself but I was googling and came upon it.
Heres a video, theres a w202 towards the end that tests them.
http://www.youtube.com/watch?v=R1kuK...eature=related
Bridgestone Blizzak are probably the best winter tires on ice. The problem is they are extremely soft tires and will wear out faster than others.
You might also want to consider: Michelin X-Ice Xi2, and Nokia Hakkapilitta
I'm currently using the Mercedes recommended Pirelli Snowsports, they're great in the snow but loosy on ice.
Best snow tires I ever had were Nokia Hakkapilitta on a Honda Civic,.... it was like a rally car,... in the snow.
Since our Mercedes are rear-wheel drive,.... put a couple bag of road salt/sand/rice in the trunk to put some more weight onto the rear wheels.
I bought my 05 C230 Kompressor in 2008 and also live in KC. I drive a lot for work, and the last 2 winters put Blizzaks on the car. First winter, all four 225-45's. Just make sure to tell the Firestone shop that the back two wheels are wider than the fronts. I had to wait for them to remount a couple because they didn't notice.
I put 13,000 miles on it that winter, and the back 2 were worn out. I kept the front 2, and put them back on along with a pair of 245-40's on the back at the beginning of last winter. If you lived here then, you'll remember that we had A LOT OF DAMN SNOW last year. I drive up to St. Joe several times a week, and had no problems at all with traction. I also put 2 cases of paper in the back seat, and 2 cases in the trunk. (print a lot for work, so I use it up and it worked for added weight over the back axle.) The 245's would probably be good for another winter's use, a lot more tread left than on the 225's.
The only problem I had was speed. Both size of rear tires gave great traction, even able to get moving uphill after stopping for lights. But over 35-40 mph on the highway, my car never felt stable. At first, I stopped a few times to have a look because it felt like a tire had gone flat. As long as I kept it under 40, I had no problems. So if you're lucky enough to never leave town you'll be fine, get a set for all four wheels (you still have to steer and stop). For out-of-town trips, though, it's really slow and it gets old having everyone pass you.
Last summer I found a good deal on an 03 Acura MDX so I got it for winter use, and I gotta say I'm damn glad my Benz stayed in the garage today. 4WD rules!
my point is do whatever it takes get 4 snow tires on your wife's car and if that means sharing a car until you can buy another set it is a small price to pay. i would hate for something bad to happen to either of you and tires play a huge roll in safe winter driving.
when we get snow in va i just leave my car at home since i have only all seasons. It's not that i fell that my car could not do it i just don't need to find out that it can't at a bad time. Next winter i will be buying snow tires for my old 16 inch rims and do what everyone that gets snow should do and have winter and summer wheels/tires.
“Thinner / (if you can get taller)…is better.”
It is also MORE ECONOMICAL to buy a dedicated set of snow rims…I don’t have the math handy – but mounting / balancing EVERY season – COSTS MONEY…the rims will pay for themselves in a few seasons.
I NEVER get past a half tank of fuel either…while adding weight will help, it is not needed…again, never had an issue in Buffalo, NY…just a full tank of fuel.
Im jealous of your winter ride... Im attending Dental School here, and my first year in 2008 I had my 2008 FWD Equinox which was a steamroller to any amount of snow.
Off topic, but are you an enthusiast of the w203 in the way of spirited driving and modification or just an admirer? Either way we could always get together sometime to oogle over our vehicles. I may even bring a jack and wrench to borrow those blizzaks when you're not looking
I have my own set of wheels awaiting to be christened this summer, and my current OEMs will next season be dedicated winter. Interesting thought on a set of winter rims paying for themselves. I'll be keeping an eye out for a used set of stock rims starting now. She's wearing the stock 5 spoke in chrome as of now anyway, it'd be nice to not let the surface get damaged from winter driving conditions.
Thank you for all your insight.
I told her I'll be buying a set just for her car alone and she must be ready to take my butt to school by 8am if duty calls in the future. It's a worthy sacrifice for both of us. We'll share her car this winter with all 4 winter tires mounted, and each have our own by next. Santa brought some X-mas money, but Cale already spent too much of it on other crap so 2 sets this season are a little much for me right now. ugh.
