sunroof service???
Old Jan 10, 2011 | 07:02 PM
mlg's Avatar
mlg
06 C350 sport 6MT
sunroof service???
have 39k miles on car, i think service on sunroof is due. says to lubricate the slide rails or something??? i have lithium grease, any suggs on how to do this??? thanx, mike how often to repeat or clean the rails???
Old Jan 10, 2011 | 10:21 PM
AdidasC230's Avatar
Saab 900 SE
I think it up in the top of the thread under the how to, if not do a search I know ive rear about doing it.
Old Jan 11, 2011 | 02:37 AM
W203E35's Avatar
2006 C350 Sport 6MT
Servicing is just opening the sunroof all the way back and:
"Coat slide rails and slide blocks thinly with grease"
Klueber Polylub GLY 801 Grease
Part# A 001 989 84 51
Old Jan 11, 2011 | 02:43 AM
phister's Avatar
06 C230 SS 6spd
always so informative Karo. I was looking for the part number for it.
Old Jan 11, 2011 | 03:13 AM
W203E35's Avatar
2006 C350 Sport 6MT
I can't find it by the part number at trademotion
These are the guys that sell them
https://www.klubershop.com/
Old Jan 11, 2011 | 11:27 AM
mlg's Avatar
mlg
06 C350 sport 6MT
thanx for the responses. pardon my ignorance, but what are the rails and blocks? i think the rail are the brushed aluminum looking peices that are shaped like a 3/4 box channel. block, i have little idea unless this is what rides in the channel??? would white lithium grease do the trick or do i need to get the above mentioned grease? do the channels need to be periodically cleaned and how often to lube? thanx , mike
Old Jan 11, 2011 | 12:47 PM
pcy's Avatar
pcy
'14 ML350, '13 C220 CDI, '07 C280, '98 ML320
how often you need to clean and lube the sunroof channels depends -
- if you park the car under trees with the sun roof opened, then you should check the tracks often for debris. Also, if you drive thru dusty areas with sunroof open, you need to clean the sunroof mechanism often.
Regardless, you should clean (wipe the tracks and surrounding area with clean paper towel or clean rag) and spray thin layer of lubricant once every 6 months. That's what I do.
Old Jan 11, 2011 | 06:05 PM
W203E35's Avatar
2006 C350 Sport 6MT
Take a look at the attached document.
5 years with the grease.
Old Jan 12, 2011 | 01:12 AM
mlg's Avatar
mlg
06 C350 sport 6MT
perfect
Old Jan 18, 2011 | 01:56 PM
SteveAustin's Avatar
2005 C230 Kompressor Sport Sedan
One more bit of advice regarding sunroofs: check the drains! I had water overflowing into the cabin due to some heavy downpours here in Oregon (go figure). I asked the dealer to check the drains and even though they said they did, they did not. I found a large leaf wedged into the driver's side drain and was able to pull it out. I forced some water through the drains and could hear it hitting the garage floor so I'm certain it's draining now. Check these drains before taking it to the dealer. Push down on the plastic guide and you will see them in the corners. The other TSB solution is to remove the sunroof and install a butyl cord around the sunroof (I may still have to have this done). The job is at least 10 hours + parts so expect to pay over $1,100 dollars if this needs to be done. Removing the sunroof requires taking off the headliner and that of course is gonna cost you tons of money.
