Caliper Opinion
Heres a pic of my car
It really doesnt matter which choice you choose, as long as its a high temp paint you'll be ok. It all comes down on how you want them to look. I prefer the anodized look myself. Duplicolor does make a caliper paint kit, also it depends on if you want to hand paint your calipers or use the spray on kits. Just go to the auto parts store and check out the selection and see what you'd like. You can always sanding them down and redo them if you're not satisfied with your results.
http://www.xenonmods.com/xenonmods_m...benz_items.htm
and check out my thread below,
https://mbworld.org/forums/exterior-...t-kit-red.html
Andy
. I put jb weld on the part where the brembo decal is and sanded it down before painting it so its smooth. I did this because stock rear brakes have some number and stuff stamped in so decal wouldnt stick perfectly on there.
I would also suggest you paint the part of the rotor where the lug bolts go so that it can look better and prevent it from rusting.
1. jack up car
2. take off wheel
3. cover surrounding area
4. clean caliper with some kind of degreecer?
5. sand caliper
6. spray on 3 coats of heat resistant paint
7. when dry, apply decal
8. spray on 3 coats of clear coat
9. when dry, put wheel back on and im finished.
am i missing anything?
1. jack up car
2. take off wheel
5. sand caliper
what size decals are those?
i am checking the ones on eBay and they are 3.28 inches by .08 does that sound right?
