upgrade to C32 intake tubes???
Old Jan 14, 2011 | 11:15 PM
mlg's Avatar
mlg
06 C350 sport 6MT
always lookin for more grunt, c32 air intake tubes are larger?? than oem in c350, can i expect seat of pants increase in acceleration w this mod?? may also couple it w magnaflow 5000 series muff. thanx, mike
Old Jan 14, 2011 | 11:40 PM
laneshift's Avatar
C240
Honestly, the tubes alone.. no. If you think about it, you're not changing anything at all without changing the airbox itself. Just because the tubes are fatter, the coupling would still have to be the same diameter as your current ones to fit on your airbox. Therefore, the restriction is still there.
Magnaflow will free up some top-end, though. My w203 revved easier with a magnaflow axle-back.
Old Jan 15, 2011 | 01:43 AM
Gramma_Benz's Avatar
2002 C32, 2012 S550
+1 The airboxes are your restriction
Old Jan 15, 2011 | 02:21 AM
cpbeasley's Avatar
"annoyance" and "self-righteousness", amoung others...
I might as well bite into this too since I have a c350 with the choked airbox. Do we have any options?
Old Jan 15, 2011 | 03:42 AM
W203E35's Avatar
2006 C350 Sport 6MT
A CLK500 with stock airbox VS SL55 Airbox was a 3hp difference on dynodynamics. There for sure is a gain but you wont know for sure exactly how much. I'm sure if you upgrade the airbox with the tune you should see a decent gain.
Old Jan 15, 2011 | 03:45 AM
cpbeasley's Avatar
what airbox can we upgrade into?
Old Jan 15, 2011 | 04:10 AM
W203E35's Avatar
2006 C350 Sport 6MT
I know the C32 guys upgrade to the SL55 airboxes and feel a difference. I'm guessing we might be able to fit an SL55 box ourselves? I really don't know if it will work.
http://www.crossfireforum.org/forum/...onversion.html
Old Jan 15, 2011 | 07:12 AM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
the M272 airbox is more than enough for the 3.5L. all you need is to change the filter so that the paper filter's side slab isn't blocking 2/3 of the inlet.
Old Jan 15, 2011 | 10:24 AM
cpbeasley's Avatar
Karo
Do you think the efficiency of the stock airbox w/ less of a filter "slab" would be enough to overcome the deficiency that OE noted during your dynotune re: choked air to the engine?
Old Jan 15, 2011 | 07:15 PM
W203E35's Avatar
2006 C350 Sport 6MT
Karo
I really don't think the air filters alone would help. Now I have K&N filters and I have shaved the baffles like most people did but I have to get it dynoed before I can confirm it did anything. The reason is I do feel my car is not starving for air anymore but it might be a placebo effect. So won't know for sure. I don't know if I mentioned it in this thread but a CLK500 gained couple of wheel power with a different airbox so I'm guessing an airbox upgrade will definitely help.
https://mbworld.org/forums/c-class-w...rbox-mods.html
Shaving Baffles
Old Jan 18, 2011 | 08:26 AM
manny_fresh's Avatar
2004 C320
Not sure if im on the same train of thought as you guys buttttt i have a c320 (w203) and i found a mechanic who for $200 will eliminate the plastic ducting going along the sides of the engine covers (which i believe include the airbox/filter) and installs mandrel bent chrome pipes with filters which can fit through the nostrils right behind the grill let me know if what im thinking of doing is totally dumb
Old Jan 18, 2011 | 11:06 AM
BigBodyBenzC240's Avatar
...a panty dropper...
@mlg, you will notice a slight difference and better response from your engine with a C32 intake upgrade since the Y pipe going into your engine is larger than the stock one but the coupling is still the same. You will get more air into the engine with this mod which will have some gains.
@manny fresh, you could easily do this job yourself with a dremel and $200 is too much for this DIY job which might hurt your engine since the pretty chrome pipes, depending on the metal, will get hot and all your doing is feeding hot air into your engine causing negative gains.
