Fuel pump help needed
#79
Super Moderator
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
Well - good news all round!! When you have some time I would be interested in why the pump failed. They have always been crimped so you have to destroy them to check.
#80
Super Moderator
#82
glad to hear your car is running again. I guess you'll be sending the car to the body shop. With this fuel pump ordeal, we almost forgot about your stint with the armored truck :-)
#84
Super Moderator
Good to hear, johnand.
Was compelled to replace both sides on mine last year -what with the now-necessary retrofitting of AMG’s superseded hardware- to the tune of ~$1000.
At least its external filter swap is an easy 15-minute/$50 task. ;)
It is perplexing why johnand’s pump failed so soon. Although both of ours had traversed similar mileage before giving up the ghost, mine undoubtedly pressurized substantially more fuel to the injectors -given its ~18-mpg lifetime average- and been subjected to escalated on/off city drive cycles by virtue its typical operational dictates and age. Note California’s CARB-mandated gasoline blend also ostensibly contains up to 10% ethyl alcohol per LCFS edict.
Found scant little debris on its intake screen during forensic investigation. It did keep wayward refinery/filling station rust, macadam and bird droppings from the impellers, though.
The trusty DVM proved its internal armature wiring had failed.
#85
Super Moderator
Interesting splinter - sounds as though the design of your pump is/was different to the Bosch articles that I have prised open. The ones I have opened had seized from dirt.
#86
Super Moderator
2007 C230SS; 2014 ML350 BT
John,
Did you use the lubricating paste that was called out in the WIS document? That stuff lists for $89.00
Not sure if I should even bother messing with it now.
Will test/dismantle the pump when I get a chance.
So you had to convert to the C55 pump and filter integrated into the sender?
I was looking at my spreadsheet and the car ran 3597 gallons of fuel through the pump until it's demise, and 1495 of it was E85.
![EEK!](https://mbworld.org/forums/images/smilies/eek.gif)
![Wink](https://mbworld.org/forums/images/smilies/wink.gif)
#87
Super Moderator
John - I presume all this paste does is allow the clamping device etc. to slip on the seal & not stretch it at any one spot??? Any microfine wax containing product that will not swell the elastomer will do that. Petroleum jelly being a good example!
#88
Super Moderator
Just drove the car this morning, and am dumbfounded how much better it runs. I have been plagued by a hesitation problem for months now, and the idle has gotten a tad rough at times to. The hesitation is now completely gone, and the idle is butter smooth. In fact, the idle is so smooth now, I have to do a double take, as I keep thinking the engine died.
I did completely clean the MAF, air duct, TB, and filter box, and put new filters in, so that could be part of it. But, I am very pleased with the outcome regardless of how I got it.
Now, just have to reschedule my body shop appointment and get that taken care of. Just don't want to give the car up, since I just got it back
![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
#89
Super Moderator
I'm delighted for you. If you can smell no fumes - leave well alone. I think you have been suffering sub par fuel pressure for a while. To me it always makes our V6 engines feel hesitant & gritty.
#90
Super Moderator
John,
Was compelled to replace both sides owing to age and a revised 5-pin harness incompatibly. Silly 203 470 34 94 pump has a MSRP of $1300.
It’s quite effective, though, as it’ll empty a full tank when subjected to ~100 miles of track day frivolities.
Still utilizes an inexpensive Mahle-Knecht external filter.
#91
2002 C230K, 2013 BMW 328, 2015 BMW X5
Used a dollop of assembly lubricant. They're still leak-free.
Splinter, were you coming from a four pin to a five pin change? What is the extra wire. The four pins are the hot and ground and then the two resistance/sending wires of the float level.
Still haven't done my redo of my fuel pump do to moving duties, but may try tonight.
Ed
#92
Super Moderator
John, sorry to ask Splinter a ? here.
Ed
Ed
legend:
X36/3 connector
M3 pump
B4/1 LH fuel level sensor
B4/2 RH fuel level sensor
![](http://i209.photobucket.com/albums/bb196/splintersAMG/W203fuelpumpwiring.jpg)
Good luck with yours.
#93
2003 c240
Hey guys, looks like my luck has come to an end with my car and i will soon be needing to replace my fuel pump also. Is it possible for you to post the WIS for the job? I want to make sure that I buy everything required before I take everything apart. Also, is there anything I should be careful of before pulling the pump out? What brand of pump should I go with? Thanks in advance.
#94
Super Moderator
https://mbworld.org/forums/attachmen...-fuel-pump.pdf
#97
2003 c240
I am trying to determine which fuel pump I need and i am seeing two different part numbers. Can someone verify which one I need to purchase for a 2003 c240?
Here are the two part numbers:
203-470-23-94
203-470-35-94
203-470-23-94
203-470-35-94
#99
2003 c240
#100
Super Moderator
The A2034702394 is the current part number for the "Delivery Unit" for you car. I would suggest a new "Seal Ring" too. Part# is A2114710579. Geez, that seal ring has been revised 3 times.
