Powering the C240
Whoever told you that you can get 370HP out of a 240 engine is STROKING you or you are just making all this up out of thin air. Either way to add MORE fuel to the fire....back in the day brabuscclass, myself and widew203 tried our best and threw 30-40-50k EACH to mod up our 240's and try figure out how we can at least make the 240 somewhat fast...but as they say-you can put lipstick on a pig, but at the end of the day it's still a pig. Good luck believing this is gonna one day happen, at least all this nonsense has brought me back to these forums from my hiatus. Thanks for the entertainment Akber from Pakistan
BTW doesn't the C240 stock produce 168hp? ROFL.
The compression on the C240 is 10.5:1.. That engine will detonate under booost. The C230k is 8.7:1
I still say TROLL...but it has been amusing in a juvenile way.
+1 post for me, and + at least one for Akber for the reply. LOL
- Buy a C32 engine used in the US - It will save you a small fortune in buggering around on the impossible. Far better than trying to build a Karachi BS special that claims the world & does nothing. Karachi is good at breaking up old ships on the beach - not building high performance engines.Remember to get the ECU & start saving for a new diff because the standard C240 article will throw it's guts in the road after a few hard starts.
EDIT - try & buy a C32 axle used while in the US.
Who has made a 350HP+ C240? I'd pay to see that.. You're quite amusing.
You'd be better off swaping in or "wedging in" a smallblock chevy in there
So tired i can't even move lol
You are going to have some connect up problems but I'm sure your mechanic if he is capable will work that through. You will need some adaption time with a Star DAS.
There is no Kleeman blower for a C240 & the one they do/did make for larger V6's would cost more than a C32 engine. Then you would need forged rods etc. etc.
I'm outta here.
Kleeman S/C will not net u anywhere near 100HP. Look up brabuscclass posts in regards to his upgrade.
I'm outta here.
Thanks though for your wisdom.
Btw was ur c class a Lorinser??
