Aftermarket HID's in Factory Bi-Xenon Housing
Old Feb 6, 2011 | 05:06 PM
AnswerSS's Avatar
2004 C230 Kompressor Sedan 6MT
Tried searching quickly and couldn't find any answers, so does anyone know how to go about installing aftermarket HID's into the factory Bi-Xenon housing? I placed the aftermarket bulb into the stock harness and it ignited, but it burned the same color as stock. I also can't remove the stock HID bulb from the housing, any ideas?
Old Feb 6, 2011 | 05:24 PM
phister's Avatar
06 C230 SS 6spd
Just buy the hid bulbs that are the same as your stock ones. The bulbs are held in by brackets so there's a little push/pull knob. Just feel around the bulb and you'll find it.
Old Feb 6, 2011 | 05:54 PM
AnswerSS's Avatar
Aren't the color temperatures controlled by the ballast though? I figured the bulb itself didn't produce the color change, it was the ballast.
The HID bulbs are D2S, and I ordered a set of D2S bulbs of a different color temp., so could I effectively just plug in the new bulbs and put them in the housing and they'd work the same?
Old Feb 6, 2011 | 05:56 PM
fookoo303's Avatar
2003 c240
The bulbs control the color.
Old Feb 6, 2011 | 06:00 PM
AnswerSS's Avatar
So just pop the OEM HID bulbs out, replace with the new bulbs and call it a day?
Old Feb 6, 2011 | 06:01 PM
fookoo303's Avatar
2003 c240
Yes. Just make sure you don't touch the glass of the bulb or it will blow. If you have touched it then clean it with some rubbing alcohol to remove any oils.
Old Feb 6, 2011 | 06:07 PM
AnswerSS's Avatar
Alright, thanks for the info. My only problem now is getting the actual stock bulb out of its socket. I tried turning to unlock like any typical bulb, but it won't budge. I took out the harness easily but it seems like there's a rubber ring around the bulb keeping it sealed tight.
Old Feb 6, 2011 | 06:34 PM
OneOfaKindTrini's Avatar
Nike Turbo Shox
Yeap, the bulb temp is independent of the ballast.. Just get a set of DDM tuning bulbs.
Old Feb 6, 2011 | 06:39 PM
AnswerSS's Avatar
Yeah that's where I got my bulbs. Can't seem to beat the deal.
