View Poll Results: What Tires are the best?
Goodyear
21
5.92%
Toyo
28
7.89%
Michelin
140
39.44%
Continental
43
12.11%
Falken
25
7.04%
Pirelli
43
12.11%
Other
55
15.49%
Voters: 355. You may not vote on this poll
W203/CL203/S203 TIRE Discussion Thread - Every question on TIRES
Rating: Thread Rating: 10 votes, 5.00 average.
Old 11-25-2002, 06:14 PM
  #501
CHATMANR's Avatar
Location: From Oxnard; living in Ocean View Hills, San Diego, CA
'01 C320 SS
So, you shaved the back spacing, correct? I might have HRE do that, or I might down size from a 9.5 to a 9 inch width.
Damn, my Supra had 18x10's on the rear with 295/30-18 Yokohama AVS Sports. But then again I had the horsepower to go with it
Old 11-25-2002, 10:11 PM
  #502
W0n6_3d4n's Avatar
C200K (w204)
Yeah i shave those part, 9 inch should be enough, lucky i didn't order 9.5 or it wouldn't fit.
Old 11-27-2002, 05:50 PM
  #503
lamscott's Avatar
c-240
Need all season tires for Carlsson rims
Okay, I've decided to go with the 1/6 evo in a size 19. I need all season tires with handling and low noise plus high treadwear ( I know how ridiculous that sounds). I only want to spend from $100 to $150 on a tire. Please give me suggestions.
Old 11-27-2002, 06:35 PM
  #504
Harris's Avatar
You have a set of huge 19" wheels, and you are putting all season tires....that doesnt make much sense. Can you explain why do you want to put all season tires instead of summer tires?
Old 11-27-2002, 06:45 PM
  #505
lamscott's Avatar
c-240
I don't know much about cars, nor wheels and tire. I live in no. cal and commute to so. cal as well. I want a good tire which I can feel safe about when it starts raining in the bay.
Old 11-27-2002, 07:13 PM
  #506
dr_feelgood's Avatar
Like Crazy
i live in the bay too and i also am about to buy new 19" tires. the cheapest i can find are the nitto nt-555 and the falkens both are 200 dollars installed. let me know too if you can find another place cheaper!
Old 11-27-2002, 07:25 PM
  #507
Franco's Avatar
2002 C32
You may want to consider Kumho.
Old 11-27-2002, 07:40 PM
  #508
KWiK's Avatar
2002 C230 : 2007 C230
You don't need all season tire just because of some rain.
Old 11-27-2002, 08:44 PM
  #509
Matt230K's Avatar
2010 C300 4matic
This is true. High performance tires are designed to be high performance in both the wet and dry. They may be no good in the snow, but they are just fine in wet or dry. Kumho's would be a good choice, they are cheap. Also, the new Yokohama AVS ES100 should be close to that price range and it is a great tire.
Old 12-03-2002, 11:51 PM
  #510
dakarMcoupe's Avatar
2000 M Coupe and 2001 C320
What size tires did the sports package come with?
Pre 2003 of course. This is for 2001 C320.
I checked edmunds and they say it was 225/60VR/16? Stock is 205/55HR16?
I can see the higher speed rating but higher aspect ratio too? could it be possible that the 60 should be a 50 instead?
BTW they were both on 16x7 rims. I would like to go with the sports package size tires when I have to get new tires (which will be soon since I'm putting on over 100miles/day)
Thanks for any help.
Old 12-04-2002, 12:13 AM
  #511
Lynn's Avatar
According to my handy-dandy, all purpose 2002 C-class brochure the Sport package has 225/50 R 16 92V tires on 7.5Jx16 wheels. Standard equipment is 205/55 R 16 91H tires on 7.0Jx16 wheels.
Old 12-04-2002, 12:17 AM
  #512
great! thanks for confirming
now to shop for the tires and oem sports rims
Old 12-04-2002, 04:14 AM
  #513
MBworld Guru
FrankW's Avatar
white and whiter
yep, it should be 225/50, not 60.
btw, if you are looking for rims, why not go up the size to 17? AMG rims might be cheaper than the OEM sport pkg rims you can only get from the dealership, unless you find the parts number.
my sister did a upgrade to 225/45ZR17 ContiSport 2 with AMG thin spoke rims up from the 205/55R16 for her CLK. It was about $1500. the ride is not harsher, but definitely hangs on to the road better. anyway, just my advise.
Old 12-04-2002, 05:38 AM
  #514
seen's Avatar
C180K
what size tires for 18" rims?
what size do you use on your 18" rims?
Old 12-04-2002, 06:30 AM
  #515
W0n6_3d4n's Avatar
C200K (w204)
u can use 225/40 and 255/40 i think
Old 12-04-2002, 11:09 AM
  #516
KWiK's Avatar
Here is what I'm running
C230K
F= 18x8 225/40
R= 18x9 255/35
325i
F= 18x8 225/40
R= 18x8.5 255/35
Old 12-04-2002, 12:05 PM
  #517
Harris's Avatar
Kwik is right. The most common sizes are 225/40/18 and 255/35/18.
Old 12-04-2002, 12:30 PM
  #518
seen's Avatar
C180K
thanx will got my babee in 2 weeks
my problem is to get the rims before or after the winter :P i do not like the car without it, but i hesitate to buy winter tires for the alloy wheels. i plan to buy the winters for the stock rims, they are 16"x6
[s]
Old 12-04-2002, 12:53 PM
  #519
Harris's Avatar
where are you located?
Old 12-04-2002, 01:07 PM
  #520
jy2010851's Avatar
2002 C320
winter tires
It's snowing pretty heavily in upper state of NY. I was wondering if anyone could give me some recommendations for the winter tires. Right now, I am thinking of the Dunlop SP Winter Sport M2.
By the way, does it matter if i have the sport package or not?Thanks.
One more question:
I have 225/50 r16 rite now. Can I change it to 225/55? I am not sure what the difference is. Thanks again.
Old 12-04-2002, 01:12 PM
  #521
avlis's Avatar
2008 VW GTI
I've got the 16" Dunlop winter sports. They replace 17" Pilots in the winter. I can't compare the snow performance to other snows, but they are definitely better than all seasons. What I can say is that they are very quiet and handle better than I expected.
Old 12-04-2002, 01:17 PM
  #522
Harris's Avatar
You should either keep your current size or even make it one size smaller for your winter tires. The narrower the tires, the better. If you dont want to spend a lot, Dunlop Winter Sport M2 is good enough because a RWD MB will not do any better even if you put the most aggressive winter tires on.
For better traction and if you can spend a few extra dollars, you can check out Bridgestone Blizzard or Pirelli Winter 210.
Old 12-04-2002, 01:43 PM
  #523
Lynn's Avatar
The factory recommended size for snow tires is 205/55 R 16. If you live where there is a possibility of using chains, they can't be used on anything wider.
Old 12-04-2002, 03:36 PM
  #524
gendrop's Avatar
2003 Mercedes-Benz C230
I chose Nokian Hakka 1 for my coupe this winter and they work very well. I switched from my previous Bridgestone Blizzak because the Blizzaks are probably better in their first season but they become absolute cr*p the following seasons... Nokian are made of a harder compound which should last longer. They handle better than the Blizzaks in snow and are quite similar on ice.
Old 12-04-2002, 04:32 PM
  #525
seen's Avatar
C180K
central europe
You have already rated this thread Rating: Thread Rating: 10 votes, 5.00 average.
Quick Reply: W203/CL203/S203 TIRE Discussion Thread - Every question on TIRES
