View Poll Results: What Tires are the best?
Goodyear
21
5.92%
Toyo
28
7.89%
Michelin
140
39.44%
Continental
43
12.11%
Falken
25
7.04%
Pirelli
43
12.11%
Other
55
15.49%
Voters: 355. You may not vote on this poll
W203/CL203/S203 TIRE Discussion Thread - Every question on TIRES
Rating: Thread Rating: 10 votes, 5.00 average.
Old 09-21-2004, 10:07 AM
  #1276
benzlvr's Avatar
Tires on c230wz
Dis anyone have the All season low profile z rated 17's as oe on thier car? Are they going to put that on these cars that are going to be sold here soon or if we have this car do we need to get different tires for the winter?
Old 09-21-2004, 10:30 AM
  #1277
wingless's Avatar
Debadged 6-Speed '05 C320 Sports Coupe
When ordering my vehicle I was told that I could not specify the tire. When my car arrived I would be permitted to swap with another vehicle on the lot.
My requirement was for a summer-only tire, which I received with the Continental Sport Contact 2 tires, so I was satisfied.
Old 09-28-2004, 11:08 AM
  #1278
benzlvr's Avatar
c230ss all season tires?
Has anyone seen a c230 ss come from the factory with the all season performance tires? I am about to purchase one but I live up north and I am not too crazy about purchasing all season or winter tires at the same time. Did MB think about selling ss's up north in the winter?
If this is not the case has anyone been able to have a dealer swap the oem tires for a/s? Thanks?
PS the all season tires are Michelin Pilot Sport A/S (Ultra High Performance All-Season) but they are only Y rated for speed.
Old 09-28-2004, 11:16 AM
  #1279
wingless's Avatar
The current summer-only MB tire selection is appropriate for the market segment that wants maximum summer and maximum winter performance. That segment uses a second set of rubber, with winter-only tires.
The all-season tires provide "acceptable", not maximum, performance, year-round. That compromise is clearly acceptable to some consumers.
Old 09-28-2004, 11:31 AM
  #1280
benzlvr's Avatar
That may be, but how does MB expect to have people test-driving and buying cars in the winter? I noticed you were in Rhode Island so you have both sets of tires. I had a c class before my current BMW and once I switched to winter tires my dealer was never able to get the tires back balanced properly ... they even replaced the tires under Michelins warranty. My winter tires were also useless after one winter due to the fact that we dont have enough winter weather to typically justify blizacks.
Old 09-28-2004, 11:40 AM
  #1281
wingless's Avatar
Two sets of wheels, each balanced, swap on, swap off. Easy.
My experience has been two to three seasons from a set of Blizzaks, then burn 'em up in the spring, prior to putting the summer tires back on.
The Hunter GSP9700 is the best tool for resolving balance problems. It requires an operator with sufficient knowledge and experience to use this properly.
The test driving during snow storms is likely very limited. After that the roads get cleared.
Old 09-28-2004, 02:20 PM
  #1282
SteveS's Avatar
2003 C230 Kompressor Sedan
I put a set of Continental Extreme Sports on last year before making several trips into snow country. I have had no problems with the tires, and they took me through many snow storms. They are W rated, but that shouldn't be an issue unless you have an Autobon that you drive routinely.
As for the Z rating vs. Y or W, this is direct from Tire Rack.
When Z-speed rated tires were first introduced, they were thought to reflect the highest tire speed rating that would ever be required, in excess of 240 km/h or 149 mph. While Z-speed rated tires are capable of speeds in excess of 149 mph, how far above 149 mph was not identified. That ultimately caused the automotive industry to add W- and Y-speed ratings to identify the tires that meet the needs of new vehicles that have extremely high top-speed capabilities.
W 168 mph 270 km/h Exotic Sports Cars
Y 186 mph 300 km/h Exotic Sports Cars
Old 09-28-2004, 06:18 PM
  #1283
samnor's Avatar
C230 Kompressor Coupe
All Season tire comparison
Hi,
My rear wheel conti's (C230 C7 package 17" rims) are worn out. I have a couple of questions, given that I drive in NJ with occassionally heavy snow:
a. Is it ok to replace the rear wheel tires alone for this winter. Front tires are not anywhere near wearing out.
b. Does anyone have experience with the following tires. I got this list from tirerack after selecting the all season ultra high performance category
1. Yokohama AVS dB S2
2. Continental ContiExtremeContact
3. Kumho Ecsta ASX
4. Pirelli PZero Nero
5. Sumitomo HTR+
Thanks,
Sam
Old 09-28-2004, 07:27 PM
  #1284
respdoc's Avatar
2019 CLS
Here you go:
http://www.albinoblacksheep.com/flash/posting.php
Or..but its a long shot, you could try our forum....
"The Tire Rack's Wheels, Tires, Suspension & Brakes Forum"
Old 09-28-2004, 07:42 PM
  #1285
rockintunes23's Avatar
Location: Delaware, United States. (First ~little~ state)
Mercedes-Benz
Until you start replacing tires every 11,000 miles on average, like me because the tires wear down... I would just go with all seasons that mercedes-benz recommends. The search thing in this forum helps also.
Old 09-28-2004, 07:46 PM
  #1286
Super Moderator
nlpamg's Avatar
2019 GT3 RS, 2017 M3 30 Jahre
Every 11k? Sheeeit!
I thought that they were supposed to last somewhat longer than that--like 20k!!
Samnor, how many miles were put on your tires? Thanks!
Old 09-28-2004, 07:49 PM
  #1287
Guest0001
Guest
Posts: n/a
Its all about max performance summer tires.
Old 09-28-2004, 10:06 PM
  #1288
samnor's Avatar
Originally Posted by nlpamg
Every 11k? Sheeeit!
20k miles....
Old 09-28-2004, 10:36 PM
  #1289
BabyBenz6spd's Avatar
2005 C230 Sedan 6spd
If it was me......right now I'm using Michilin Pilot Sport that came with the C230K sedan. They are awsome. But after they wear out I'm going to get Michilin Pilot A/S (All Season)
Its just as good as Pilot Sport, except they are built for All Season. My friend has them on a 2004 BMW M3. They are however most pricey in the class, but it will be worth it after it save your life just one time, or prevent you from a accident.
Just my contribution to this thread.
Old 09-29-2004, 09:23 AM
  #1290
SteveS's Avatar
Originally Posted by samnor
Hi,
3. Kumho Ecsta ASX
5. Sumitomo HTR+
Thanks,
Sam
I have the Continental ContiExtremeContact on my c230SS. I replaced the Michelin Summer tires last year when I new I had some up north winter trips planned. They more than paid for themselves numerous times. I have about 18,000 miles on them and had them checked yesterday. Based on the tread depth left, I have about another 5,000 on them before replacements are needed. A key to tire wear is rotating them every 5,000 miles, something you cannot do on the 2004.5 and newer C's thanks to the staggered sizes.
Old 09-29-2004, 09:39 AM
  #1291
mctwin2kman's Avatar
I have ContiExtreme's and they are great. Dry traction is a hair less than the Pirrelli's that were stock, but wet and snow traction is much much better. The trade off was minimal and they work great. Although I failed to rotate them quick enough and may now need two new tires for this winter!
Old 09-29-2004, 10:01 AM
  #1292
tuscanraider's Avatar
Bantha
take off the Summer tires, and just get dedicated snows....ON ALL FOUR CORNERS! I'm in Jersey too, it the best way to go.
Old 09-29-2004, 11:43 AM
  #1293
wingless's Avatar
There are those who do not want the deminished performance compromise associated with all-season tires. The extra cost of an additional set of rims, which is partly recouped when the vehicle is replaced, is offset by the improved safety and performance year-round. The extra cost of rubber is a wash, as miles on winter-only tires would need to be put onto some tire anyway.
Old 11-16-2004, 11:09 PM
  #1294
Texas_Benz's Avatar
'05 C230wz SS Black on Black
2005 C230 SS - problems with Mich Sport tires ?
OK - I searched past posts and could not find any help.
I purchased my 05 C230 in May of this year. The Sport sedan has staggered tires that cannot be rotated. The front tires seem to wear pretty fast - I drive fairly normally.
HOWEVER, when I am slowing down to come to a complete stop - the car pulls and the wheel does a full quarter turn before coming to a dead stop. Nothing is wrong with the alignment.
I have heard that the 05 C230's bought before July 2004 have bad Mich Pilot Sport tires on the car - and MB will do nothing about it. Heard that cars bought after July 2004 do not have this problem.
Anyone else have alignment problems due to the front Pilot Sport tires?
NEED HELP!
- Trace
Old 11-16-2004, 11:20 PM
  #1295
MBc230's Avatar
2005 C230 WZ
I just bought mine last week and it comes with the Michelon Pilots as well, but I noticed the steering column is off centered a little and the car leans slightly to the right when its centered. Another friend of mine got his car in July but his SS has the Continental tires on it. His car also leans slightly to the right.
I might have them take a look at my alignment next week to check on that if any problems. But if your wheel turns a quarter of a way, that sounds like a big problem then, were you able to take it to MB service to look at it? Have you "lowered" your car recently? May be the case your camber (if inside/or outside edge of tire is wearing out quickly) needs to be adjusted. Also might wanna check your tires are balanced properly (can notice this if steering shakes at high speeds).
I think I read another post on here about someone's '05 leaning slightly to the right as well. Anyone else having this issue on their 05 c230 SS? Would be good to know if we need to take them in.
Old 11-17-2004, 12:27 AM
  #1296
Outland's Avatar
2002 C230 Coupe(M111)
Sounds stupid....but check the air pressure in the tires. The pilots behave funny if the pressure is different even a little from side to side. If not, well, something else is messed up. Hit a big pothole? That can break belts in the tire, as well as mess up the control arms.
Old 11-17-2004, 02:50 AM
  #1297
W0n6_3d4n's Avatar
C200K (w204)
Could be just a simple tram lining, my car does that a lot especially with the road that truck use often, and i use Yokohama with aggresive V shape pattern.
Old 11-17-2004, 02:56 PM
  #1298
mick1's Avatar
2005 C320wz
under normal condition, how many miles can you put on the tires that came the 17-inch wheels before you have to replace them ? just a rough estimate will do.
thanks.
Old 11-17-2004, 07:19 PM
  #1299
W0n6_3d4n's Avatar
C200K (w204)
Hmm, my brother lexus with 17 inch last for 71.000k or 5 years of normal driving, still wearing factory tyre when we sold it, we rotate them regulary though, and make sure tyre pressure are correct.
Old 11-17-2004, 07:24 PM
  #1300
viper's Avatar
thanks.
You might get 15,000 or you may get 25,000 miles. Depends on how well you keep them inflated and how hard you push them. If you like cornering at high speed at or near the limits of adhesion you will wear them out pretty fast.
You have already rated this thread Rating: Thread Rating: 10 votes, 5.00 average.
Quick Reply: W203/CL203/S203 TIRE Discussion Thread - Every question on TIRES
