View Poll Results: What Tires are the best?
Goodyear
21
5.92%
Toyo
28
7.89%
Michelin
140
39.44%
Continental
43
12.11%
Falken
25
7.04%
Pirelli
43
12.11%
Other
55
15.49%
Voters: 355. You may not vote on this poll
W203/CL203/S203 TIRE Discussion Thread - Every question on TIRES
Old Mar 27, 2002 | 10:42 PM
  #151
galaxygrrl's Avatar
c230k, black, auto, c2 (let the sunshine in), Bose, leather, and CD
Post pictures of that will ya!
:p
I would take Benzo as a little bro any day!
Beth
Old Mar 27, 2002 | 11:06 PM
  #152
Lynn's Avatar
Originally posted by tommy
References are a funny thing. Noone seems to get MB-BOB's "Steward's Folly" or "Tippicanoe and Tyler Too" references from when he was growing up.
As MB-BOB's contemparary, I must correct you. The purchase of Alaska was Seward's Folly. The steward's folly was accepting employment on the Titanic.:p
Old Mar 27, 2002 | 11:15 PM
  #153
tommy's Avatar
2004 Civic Si. FWD for the Win!
You know, I knew that I screwed that one up somehow. Thanks for correcting me; there's nothing like being there when an event takes place.
I should've gone with Teapot Dome or Boss Tweed. Damn that 7th grade history class!
Old Mar 27, 2002 | 11:59 PM
  #154
Lynn's Avatar
I think I remember Boss Tweed. Wasn't it a funky haberdashery in the Village during the '70's?
Old Mar 28, 2002 | 12:37 PM
  #155
trench's Avatar
2002 C230 K
I think the words funky and haberdashery are mutually exclusive.
Old Mar 31, 2002 | 06:52 AM
  #156
BruNo's Avatar
07' ML350
255mm rear tires???
hmmm is it safe to use 255 mm tires for the rear on 9" x 18 rear wheels??? im a bit concerned that they might RUB when i seat 5 people with luggage on the car. BTW, im not lowering my car. AMGs i know only use 245 for the rear....
also read once that 255 needs some sort of rear axle modification.......
any ideas???
Old Mar 31, 2002 | 09:51 PM
  #157
renncpe's Avatar
w203 c230K 2002
I'm running 18x9.5 rim's with 255x35 tires and lowered alot, I do not have any rubbing problems with 4 passengers and a 65 lbs bass enclosure in the back.
Randy
Old Mar 31, 2002 | 10:59 PM
  #158
Norm C32's Avatar
ex-C32
Randy, what offset are you rear wheels in the rear? Front?
Are you using spacers?
Norm
C32
Old Apr 2, 2002 | 04:06 PM
  #159
shen_q's Avatar
tire life between stock vs C7?
For the C230 Coupe, what is the difference between the 16" stock wheels (H Rated tires) and the 17" C7 wheels(Z rated tires) in terms of tire life?
Old Apr 2, 2002 | 05:31 PM
  #160
timorgan's Avatar
Buick Park Avenue Ultra
Hello Shen!
I went in search of an answer to your question, and have not come up with one as of yet (I'm sure many on this board will be able to answer your question).
I did, however, find an informative page regarding tire ratings.
http://www.tirerack.com/tires/tirete...eral/speed.htm
Just a good spot for some information on the different letter ratings!
Tim
Old Apr 2, 2002 | 06:32 PM
  #161
Buellwinkle's Avatar
It must depend on which tires you have. I've looked at various C class cars and the tire brand varies. Also driving styles vary thread life. My wife can only get about 15-20K miles from a set of tires and I can usually get double that. My friends C320 with the 16" Continental's are ready for replacement at 15k miles. The dealer said 20K is normal. I can't imagine the C7 tires being much worse.
Old Apr 12, 2002 | 03:09 PM
  #162
SFVideoGuy's Avatar
1995 Acura
Tire puncture in 230K Coupe...
I just found a huge screw in the tread of a rear tire of my 230K. I went to a gas station where they pulled out the screw and plugged the hole with some orange rubbery stuff. After inflating, they sprayed it with some liquid and saw that it wasn't bubbling (no air leaking.) The plugged hole is at the very edge of the tread--right above the sidewall. If it doesn't leak anymore, it it safe to drive? Should I worry about a blowout? I hate to spend $100+ on replacing an essentially new tire, but I don't want to get stranded either. Thoughts?
Old Apr 12, 2002 | 03:37 PM
  #163
RedC230K's Avatar
'04 Mars Red C230K 6 sp.
I had to plug a tire on my car and it has held just fine for several weeks.
We should be just fine.
Old Apr 12, 2002 | 03:46 PM
  #164
kompress's Avatar
Unhappy
Sorry to hear about the tire. In my experience, plugs-- especially if the screw was big-- are rarely a good long-term fix. Tires are too important if you do any type of highway driving to run in anything but optimum condition. You should be fine short-term until you can get a new tire. But that's exactly what I would do in your place. Just my opinion, though.
Old Apr 12, 2002 | 06:17 PM
  #165
Steve H.'s Avatar
2002 C230K Sport Coupe M6 C5 desert silver
As long as the hole was in the tread region you should be fine. I once had brand new Pirellis on a car and ran over a rake. Two holes. Under duress the guy plugged them and I got 45000 miles out of them with no troubles. I have plugged other tires and gotten at least 20K so you should be okay
Old Apr 12, 2002 | 06:19 PM
  #166
SFVideoGuy's Avatar
1995 Acura
Thanks Steve.
I'll cross my fingers and go with it. If I get stuck--there's always FOR-MERC!
Old Apr 12, 2002 | 06:21 PM
  #167
SoCal240/6's Avatar
'01 C240/6
A plug may be ok, but a patch on the inside would be better.
Old Apr 12, 2002 | 07:39 PM
  #168
BlackC230Coupe's Avatar
Former Vendor of MBWorld
Fast Cars!
sorry
sorry about the tire i know how u feel i felt worse the day i bought my Jaguar XK8 right when i bought it i went on the highway and took it for what i thought would be a fun drive but all the sudden about 10 min into the ride i got flat i pulled over and got out and saw it and felt like crying it was so badly damaged i had to buy a new tire and these are Pirelli P Zero and they are pretty expensive espcually if the tire was brand new and not to mention i only had the car for 20 min the most. buy by the way i think a patch would be better. but maybe u will get lucky hopfully.
Old Apr 13, 2002 | 10:58 PM
  #169
VoyagerDude's Avatar
2002 C230K, Silver, 6-speed, Evo, Roof, Leather, CD, Staggered C7 Wheels
Question Wider 17" tires
I was wondering whould it be a good idea to use a wider set of tires in the back with the C7 wheels?
Can I fit 245 tires on them?
The original tires are 225/45/17
Should the wider tire size be 245/45/17 or 40/17 ???
I guess I should post this in the tires forum
Old Apr 13, 2002 | 11:24 PM
  #170
sLaMmEd230's Avatar
2002 c230 coupe
wut i would do is just go one size wider in the rear wit one size lower profile..so 235 40 zr 17 should b good 245 mite b a lil 2 wide and mite slow the car down but it would handle sick wit them good luck
Old Apr 13, 2002 | 11:25 PM
  #171
TimmyC230boy's Avatar
From: Sitting behind thing freakin desk of mine. Dreaming I was playing my Taylors, and driving my Benz. Long Live The VRAA!!!!!!
C230 Sports Coupe
if you do then you cant rotate your tires.
Old Apr 13, 2002 | 11:29 PM
  #172
C230 Sports Coupe
You can run a 255 in back but, if i recall only a 225 in front. Although I seem to remember someone with a 255 in front. But if youy only wanting more grip just get a softer stickier tire. S03's and Kuhmo's ecsta's are good. Or some Michelin Pilots sports, too.
Old Apr 13, 2002 | 11:36 PM
  #173
vadim's Avatar
'19 GLC 300, '19 TM3SR+
suggestion:
should = too many letters. should be "shude" or even "shud"
them => dem
luck => luk
the => de
ThEn It WoUlD Be FuN tO ReAd!
Old Apr 14, 2002 | 12:09 AM
  #174
Yes, I have Michelin Pilot Sports for summer tires.
OK, here are my calculations:
Current tire size is 225 45 17, so
225 * 0.45 = 101.25 mm is the sidewall height,
so the closest sidewall to 101.25mm with the wider tire would be:
255 * 0.40 = 102.00 mm
My Degree is Math comes handy sometimes
So a 255mm wide Pilos Sport would be a nice looking tire for the back, of course the only way I can rotate them is side to side, by removing the tires from the rims.
Which may actually work, because I'm using the Pilot Sports only in the summer and in the winter I have Pilot Alpins on the same rims.
Provided 255mm tires fit in the rear, what other disadvantage will I have? Performance? please help.
Old Apr 14, 2002 | 12:11 AM
  #175
vadim's Avatar
Try this site, very useful. Helped me big time:
http://www.miata.net/garage/tirecalc.html
Michelin PS 255/40/17 requires a minimum of 8.5" rim => no go with the standard C7/Evolution one which is 7.5"
ALso, they are rated at US$238 apiece... kind of pricey...
You have already rated this thread Rating: Thread Rating: 10 votes, 5.00 average.
