What's the SOUND sound system?
Originally posted by Matt230K
I hardly ever parallel park and it tilts down way too far for normal parking. I really hate backing cars into the showroom and the mirror tilts down so far that I can't even see the frame of the door anymore.
Guest
Posts: n/a
No, I don't have power seats. I'll try to check that out too. Although I never did like that feature. I hardly ever parallel park and it tilts down way too far for normal parking. I really hate backing cars into the showroom and the mirror tilts down so far that I can't even see the frame of the door anymore. I always have to aim it back up since there are only about two inches on either side of the mirrors till you hit the doors.
You'll have to explain that one a little better. I'm not sure I know what you're talking about.
What I understood that to mean is that if a bulb goes out another one *temporarily* takes over its function. Maybe I misread some old posts (can't find, probably wrong search words!). Please educate me.
Thanx
#32
Originally posted by amdeutsch
Matt,
Thanx
Matt,
Thanx
#33
Originally posted by shortbear
hey matt, can you turn on the TV function on the US Comand navigation system units? It is that blank button on the bottom left on the COMAND.
#34
2002 C320 Sport *SOLD*, 2006 BMW 325i
I started a thread a couple weeks ago about my sound system not sounding the same after I got my speakers replaced from the dealer. I wonder if they could have deactivated my Sound sound setting.????
#35
#37
'00 ML320 Elegance/'03 C320 4-matic
The setting doesn't seem to do much. I've had it turned on an off in my car, just to see how it would affect the Bose system. In short, it hasn't. For some odd reason, just recently the Audiopilot system has been raising the volume significantly when the ambient noise increases. It used to be very subtle but has changed for some reason. I'll probably have the option turned back on again, along with the vehicle responsive volume set back to on (it's currently off), but this time at 3dB rather than 0dB.
#38
OK, here are my findings after playing with the DAS:
1) The SOUND sound system setting does not have any noticeable effect that I could tell.
2) amdeutsch, the replacement light function was also "inactive" on my car, so I'm not quite sure what that is all about. I guess I could pull out a bulb and see what happens. However, I did find out that you can disable the turn signal on the mirrors, not that there's any reason to.
3)taylor192, there is a setting to enable the mirror feature. There is a setting for it in each door control module, and I turned both of them on, but it doesn't seem to work. I don't know if it has anything to do with having a 6-spd. Hopefully someone with power seats and 6-speed can tell us if their mirror tilts down in reverse. (mctwin2kman, I know you have those two options.)
I think that is all that I messed around with. I didn't have as much time to waste as I thought I would. And even though I essentially accomplished nothing, at least it should answer some questions.
Oh, Outland, as for the CD, the computer I was using is not even a regular laptop and it didn't seem to have a CD drive, unless there was something that opened up on it. It is kind of like a tablet PC with a touch screen, but a little bit bigger, and with some rubber coating to protect it.
#39
2002 C230 Coupe(M111)
Thanks for the research, Matt!
Your computer sounds a little different than the ThinkPad that Kleeman posted pics of. Interesting.
Thanks again.
Thanks again.
#40
Matt, it was inactive on my car as well. Apparently it is on all cars here, not just the C-class. I can tell you for a fact that it does work though, since my foglamp came on to substitute the city lamp when I was replacing the city lamp bulb to the LED bulb.
#41
Has anybody tried to decifer the communication between the DAS computer and the vehicle? First you'd have to capture the data by tapping into the wires of the connector in the car then connect with DAS and send one command like changing xenon to present. Then look at the data log and see what happend. Hopefully this could be used to make/rig something without the need of a full blown DAS for things that most of us want changed.
