Alarm siren and battery placement
Here is a picture of the siren mounted in a metal shield. The red wire is going to it. That is the connector I unplugged.
While you have the liner down, why don't you remove the alarm and follow the wires inside the alarm.
if your alarm siren is marked with this code (203 820 38 26), like in mine W208, the battery is inside the unit.
This unit can be opened by removing the two screws on the back and by patiently open it (it's possible that it was sealed with silicon, like mine).
Once opened, you can easly access the battery.
The battery is a 7,2V 140mAh composed by 6 Varta V150H elements in series.
I was unable to find the exact replacement with cable and connector, but it's quite simple to adapt a "standard" 6/V150H battery. You have just to solder the original cable on it, respecting the polarity.
Check if the circuit board was damaged by the battery acid. I had to wash the entire printed circuit board and rework some soldering in my unit.
Bye,
Edoardo.
Also - Should I disconnect the main car battery prior to installation of the alarm sounder? I have heard horror stories about things going wrong when the battery is disconnected.
Stewart
* The bolt is T40 ... I drilled out the security pin so I could use a normal torx bit ... the metal for this screw is soft so it took only a few minutes to drill out the pin.
* I cut the housing apart using a Dremel with plastic cutting wheel ... kind of a mess ... a tabletop bandsaw would have done much better. Just cut around the opening and go in only 1/8" or else you will cut into the components inside.
* As you can see from the pics, the PC board is kind of a mess. I'm not sure it's worth the hassle at this point of spending $30-40 on new batteries, trying to clean that PC board, and then gluing the case back together so that it's intact and waterproof. But I at least thought I would pass these pics along in case someone else wants to attempt it.
T40 bolt .. I drilled out the security pin.
The folks in the tech forum pointed me in the right direction as to it being the alarm module as
www.charm.li W203 manual had nothing about it. I actually DID see a fault for short at alarm module but no idea how old it was
and cleared all errors on the car, since a lot has happened since I ever cleared everything last.
I didn't know the 2 were related, locks, fuse 8 and alarm.
https://mbworld.org/forums/mercedes-...king-help.html
So the module is out and no more blown fuses.
Those crappy Varta batteries are $23 each on ebay.
I don't have it apart yet to check the dimensions as I dont have a dremel or a hot knife,
but wondering if something like like this could be used instead.
https://www.batteriesplus.com/productdetails/cot10028
Just jumper to the 2nd location, has more than enough current for both locations.
OR if the board isn't fried, just toss 'em and fuggetaboutit. OR
just leave the alarm out.
OK, well I was able to get the module open without much trouble at all.
Mine has 2 tiny torx screws holding together, and then it only took a little effort
starting with a tiny screwdriver and moving to a larger one to pry it open.
What I found inside is completely different than whats shown in previous posts.
So it appears the 2 Varta batteries are SERIES not parallel as it is 7.2V and 250mah.
Anyway, so far not finding this battery anywhere and the date code on the board is 2501 as in 25th week of 2001. Part number is 2038203826,
Battery is 2 stacks of 3 button batteries in each. Strange they went to 2 batteries, and they didn't hold up as well as these.
23 years and no major leak, although it appears some stuff wicked up one wire and
the pin came out with the connector when I removed the battery.
If I decide to even bother with it all, as the car is already buttoned up,
I think I would either run a wire from the other side of the board if I can find a similar battery or,
just skip the battery.
MADE IN ITALY!
I always told my service advisor during my MANY warranty visits."Mercedes builds the best Italian cars in all of Europe!"
I even had a Magnetti Marelli starter! But they sourced it from Denso so in the end, it was not from Italy.
As I said, some stuff wicked up through the wires which is quite visible here as well as the missing pin.
Well too bad I buttoned up the car already. I don't feel like repeating the process today just to see if it works without the
battery. Plus I don't have anymore 7.5 amp fuses if it doesn't. I guess I'll wait until I have a reason to be removing the right front wheel again.
No one ever tried to steal or broke into my car. Knock on wood.
I was VERY lucky. Car break ins happened nightly where I lived, shattered windows etc.
But it's pretty quiet here, so not sure if it's even worth bothering to put the module back,
and definately not worth putting new batteries in that might leak AGAIN IMHO.
There's a reason they deleted them later.
What are the odds someone will disconnect the car battery and
then break into the car? They'd set off the alarm opening the hood straight away.
BUT I said, the next time the wheel is off I'l see what happens.
