Oil change (drain) - torque specs
Hers - 2003 C320. His - 2004 330i zhp 6 speed.
I am having a hard time finding any info on doing an oil change on a c320 using the drain method. Seems like most people use a pump to suck out the old oil, but I would like to drain it which is what I've been doing on my bmw for a long time. Couple of quick questions:
1) What is a factory specified torque on the drain bolt and on the filter cover in the engine bay? I would guess 18 ft/lb but would like to confirm.
Answer: Engine oil drain bolt torque = 30 Nm per MB shop manual. Oil filter cover = 25 Nm. Do NOT overtighten.
2) Sounds like people recommend changing the drain bolt crush washer or it will leak. The filter kit on my 330 comes with a new crush washer, but the filter I got for the MB does not include one. Should I get it at the dealer or do they sell stuff like this at Autozone for example? I know they are available online, but I need it now.
Answer: Dealer has them for around $1. Online place like autohausaz.com has them for about 20 cents each. Or can check another store for these specs: 14mm Copper Seal Washer 14x20x1.5mm
3) Where is the drain bolt located under the engine on a 2003 c320? I saw some people say that both the front and rear splash shields need to come off, but that was on a 230 I think. Just want to make sure I know exactly where to look for the bolt.
Answer: See picture in PCY's post for a 4Matic only. Follow the engine down to the lower pan and the drain plug is on the passenger side of the plan. Only the front splash shield needs to be removed to get to the drain bolt. Non-4mMatic cars have the bolt facing the rear of the car in the middle of the pan.
Last edited by vert; 02-22-2011 at 10:04 PM. Reason: Added answers so it's easy to search later
I have '04 C320, same as yours. I also drain oil via drain plug. I don't know the torque number for the drain plug. First I finger-tighten the bolt, then I turn half turn further. By then, the bolt is real tight. I replace the copper crush washer every time I open the drain bolt. I bought a pack of 100 assorted copper washer pack at HarborFreight store for $5. Individually, MB sells them for $1 each washer.
The lower panel under the engine (only the larger front panel) needs to come off to access the drain plug.
Red arrow in the picture below is pointing at the drain plug. Ignore the oil mess on that car. That is how it was when I bought the car - the oil was leaking from the oil level sender unit. Since then, I have had the oil level sender unit replaced and cleaned the entire area. Now, it's squeaky clean.
A picture is worth a 1000 words for sure, thanks for that. When I bought my 330 the bottom of my engine looked like that as well due to a leaking oil housing gasket... I don't know how people can sleep at night with this mess down there
I'm sure someone must know the correct torque settings for the bolt and the filter cover and will chime in.
1 Post
C320 2002
Engine Oil Drain Plug 141 In-LBS or 16NM is what it should be torqued 2
Got the torque for the filter cover?
1 Post
C320 2002
Do not use a ft-lb torque wrench. Most foot-pound torque wrenches are not accurate at these smaller values. Make sure its set to 141 In-lbs
2001 E55 AMG (sold)
I agree that torque number sounds awfully low and I'd double check it.
The spec for the M272 engine is 30Nm (or 22ft-lbs). I just don't see the torque being half of what the M272 requires, but I could easily be wrong.
1 Post
C320 2002
If you think that is low. Your Automatic transmission pan bolts are 71 In-lbs and 8NM for the 722.6 Transmission. For the 722.9 Its 35.4 IN-lbs 4 NM and then you tighten an additional 180 degrees.
Please do not give out the wrong torque info if you don't know if its correct or not. Ive done the job many times.
The locknut washer does all the work.. If you over tighten it you will destroy the washer causing a leak
Maybe that's the problem? I was asking about an ENGINE OIL drain plug torque, not the transmission drain plug. Could you look up the value for the engine oil drain plug in your MB shop manual? Also, they would probably list the the filter torque as well so if you can post it up that would be great!
PCY - is your picture for Engine Oil plug or Transmission Oil plug?
You don't have to tighten the engine drain plug whole lot; the copper crush washer is there for a purpose...
FYI, Engine oil pan is [shiny] aluminum. Trans oil pan is black color.
1 Post
C320 2002
The picture I posted is showing the engine oil drain plug. You can't miss it. Just follow the engine down to the lower pan and the drain plug is on the passenger side of the plan.
Xhale, since the torque you gave is for the engine oil drain plug and it is from the MB manual, I'll just set my torque wrench to 141 in-lbs when I tighten it. I was just confused when you started taling about manual transmission and automatic transmission torque values for some reason in your previous post.
BTW, I wanted to get the spark plugs for the 320 anyway so I ordered those from autohausaz.com (free shipping) and picked up 4 crush washers from them at under 20 cents each. They ship fast so i'll just wait a few days to do an oil change.
Ideally start in the morning when the engine is completely cold, your hands will thank you.
1 Post
C320 2002
Cool, that's what I thought. I asked because Xhale started talking about transmission oil drain plug so I thought maybe the picture that you posted looked like transmission to him
Spark plugs. Im using 4 prong spark plugs i never had to put any crush washers on mine. Mine came with washers already i believe. I felt a huge increase in power after changing my plugs
The picture shown is incorrect. That is not how our engine pan looks. You will find that out because the bolt to remove it is on the wrong side.. It shouldn't be on the side it should be in the middle facing the rear end of the car.
Oh, in regards to spark plugs... I was just saying that i ended up buying the oil drain bolt crush washers since I was already placing an order for spark plugs anyway so the shipping was free. I bought 12 spark plugs and 4 crush washers for the next 4 oil changes.
I updated my first post with the answers you guys provided because this thread became pretty confusing for anybody who tries to search for this info later.
Vert, if your car is not a 4matic, then your pan will look like the one shown in the left side of the below picture. Part #41 is the drain plug.
2001 E55 AMG (sold)
Those torque values are for a Manual Transmission drain plug. I will repeat myself for the last time. Those are correct values i put.
http://i33.tinypic.com/dov1u8.jpg
http://i33.tinypic.com/2w3vt4x.jpg
You can't compare the tiny aluminum transmission pan bolts to a large steel drain plug either, vastly different thread strengths. BTW, its not a locknut washer, its a crush washer.
Is there anyone with STARtek who can look this up for the M112?
I second billbillw's request - if someone can doulbe check the oil drain bolt torque for M112 in some official MB documentation it would help to put this issue to rest. On my 330i the bolt is similar, has the same crush washer and the recommended torque is 18 ft/lbs on both the drain plug and the filter cover, so 11.75 does still sound a little low.
2019 C300 Wagon; '75 Triumph TR6; previous: 2004 C230 6spd sold after 17 years of driving
I was told the correct way is to suck the oil out, that way I don't have to remove the undertray or worry about the drain bolt. The dealerships also suck it out of the dipstick tube. I use a 6.5 L Moeller fluid extractor pump which is quick, safe (no need to get under the car or risk of the drainbolt leaking), and free of any mess or drips.
http://www.moellermarine.com/afterma...id_extractors/
This pump is used throughout the marine industry and gets all the oil out as I am not ever overfilled if I add the spec amount of oil to my engine
I just want someone to confirm the torque numbers!
Does it say anything about the filter?
no specs are listed for the filter housing other than it says 'securely' Since there are multiple O-rings you don't usually risk a leakage if it is under torqued. However since it is plastic including the nut on top (for the 4cyl); you must use a filter wrench with a socket drive for the filter housing on a v6, just use caution and don't over tighten (snug but not super tight)
Super Moderator
Please do not give out the wrong torque info if you don't know if it's correct or not. I've done the job many times.
Note aftermarket manuals (e.g., Haynes, Chilton, etc.) are often rife with errors.
Just wouldn’t be right to give a BMW pilot faulty intel on MBWorld.
Have been twisting wrenches for a while, but don’t recall using a torque wrench on a drain plug.
Probably just dumb luck none have ever stripped, leaked or vibrated loose.
FWIW, MB specifies 30 Nm for the M112’s drain plug:
