2003 C230, p0135, Electrical Issues
Old Feb 27, 2011 | 06:57 PM
aolsen's Avatar
2013 S550, CLS500, ‘03 SL500, “92 190E Sportline
I have a 2003 C230 Sedan (m271 engine) 135k miles.
I've had a p0135 code for months, with bad gas mileage. (I can barely get 25mpg highway, where I used to get 30+)
p0135 Code: 02 Sensor Heater Circuit Malfunction, Bank 1, Sensor 1
I replaced the 02 sensor with a Denso direct fit sensor, code did not clear. I replaced that sensor with a Bosch Dealer sensor, code did not clear, gas mileage still bad.
If I clear the code with a scan tool, with the car on, the code will stay off while driving. However, if i shut the car off and restart it, the CEL instantly comes back on as soon as I start it up.
I replaced the alternator and voltage regulator, thinking the regulator may have been the culprit, but still nothing has changed. I've also recently changed the MAF Sensor, spark plugs & Ignition coils, and serpentine belt.
Anyone else have a problem similar to this? Also around the same time, my headlamp washer's stopped working, passenger seat motor became inoperative, and the SRS light is on (passenger side occupant sensor).
Would I possibly need a new wiring harness? I did fix the cam sensors a while back with MB's isolating wires & new cam sensors.
Any help would be appreciated, thanks!
Old Feb 28, 2011 | 12:34 PM
Glyn M Ruck's Avatar
Super Moderator
Is there any sign of oil having migrated through the engine harness to the O2 sensor connectors?
Old Mar 1, 2011 | 08:15 AM
aolsen's Avatar
Nope, 02 sensor connectors are dry. That's what I originally thought the problem was.
Old Mar 1, 2011 | 05:27 PM
Smokphattys's Avatar
2003 c230 kompressor, 1997 jaguar xk8
did you get the vacuum hose recall dealt with?
Old Apr 7, 2011 | 08:56 AM
aolsen's Avatar
Sorry for the late reply. Yea I had that done. When the hose issue occurred my car shook violently and had very poor gas mileage and threw multiple codes. Now my issue is one constant p0135 code, and poor gas mileage. The car shakes sometimes for about 30 seconds after startup, then idles fine.
Old Apr 7, 2011 | 04:51 PM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
And you are 100% positive the O2 sensor is OEM? There are others that will fit, even other Bosch ones that will fit, but they won't work right.
Old Oct 28, 2011 | 02:36 PM
frankyg's Avatar
clk 320
did you ever figure out what was wrong with the p0135 problem?
