front turning signal problem
At first i thought it was the bulb, so i went and bought new bulbs, i put the new bulb in but it still didn't work. So i took my old bulb from the left side and tried put it in the right side, and it worked no problem..
Then i noticed this.
My left turning signal bulb socket has wires connected to it
Although, the right turning signal bulb socket has no wires connected to it.
Why would the right one have wires connected to it ?? And, does anyone have any advice or suggestions on how to fix the turning signal ?
Did you purchase normal bulbs or did you get something special like LED's, etc?
But the left one, that is not working has wires attached to it. It seems like someone put them in for some reason.
I'm not sure were they are going, but ill take some more pictures and check it out in a moment.
Also, while they were tapping into the socket, they might have damaged it while soldering, etc. If you have a voltmeter, you might want to check to see if there really is power there...if you have a good ground, etc.
i don't know where i should take it for repair
This looks like a retrofit that someone has made to get around this problem...and now your HID install must have loosened the wires as well.
If so, I would recommend trying to find a new socket online and get rid of the band aid new wires fix.
If you want to keep the wires, check the housing end. The wires might have lost connection between the wires and the terminals on the socket.
Your best bet is to cut out those wires and pick up a socket with unwarped terminals (its pretty cheap) and fix this problem once and for all.
the second wire is the ground for the indicator conencted to a groundingpost ont he cars body. This is a complete RICER fix...belongs on a civic
the socket is not always the problem sometimes it is the headlight side of the connector that goes bad. That was the problem on my original headlights.
So i guess something has gone wrong with the oem fix. I really don't know to much about electricity and wiring so i have no idea how to fix it. Does anyone know if the dealership can fix it or ?
If you cant fix it, Im sure any reasonable Indy/electrician will be able to....unless of course you stay awake all night wondering how youre going to carry all that money you have around on your person the next day
But, why would i need to do anything to the working socket, if it works in the left headlight it should work in the right one as well.
When I had this issue on my old headlights, sockets 1 and 2 wouldn't work on the left headlight, but socket 2 would work on the right and socket 1 wouldn't. It just depends on the exact state of the terminals on the headlight and the socket...they may make contact on the left light and may not on the right.
