I have an question about the ML350 motor
2006 ML350 back from dealer after 4 weeks,now back for oil consumption test!,2003 C230 Sport
Sorry to post this here but this forum seem to have the most activity an knowledge. I have an 06 ML350 and I have noticed that this thing burns an quart of oil an month. Now this SUV has just had two small oil leaks fix two the tune of $3000 and a oil change. But still after an month of driving the check oil light has come back on. The dealership has put it on the oil consumption bulls***. Now guys do the C350 have this problem? Any info will help thanks
'14 ML350, '13 C220 CDI, '07 C280, '98 ML320
On M112 W163 engine, there is a known problem of seals around the intake/throttlebody are known to cause oil consumption. If you search on W163, you will find what I am talking about. I am not sure if that is relevant in your case.
THANKS for the info anything is better than nothing. I will google that maybe this motor suffer the same problem.
2010 Mercedes-Benz E350
Super Moderator
Karo's car indeed used to consume a lot of oil & it was due to leaks. There has been the odd 350 that genuinely burn oil. I'll try & find Karo's thread for you. The whole saga is in there.
Once leaks are sorted. IMHO the only way to check if the engine is mechanically sound is to do a leakdown test. This will indicate if oil is getting past the rings or down valve guides etc.
Benz do a standardised oil consumption test. I think the test is OK - I question their analysis of the results as to what is normal.
Super Moderator
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort (What the heck, it gets 38 mpg!)
If you have an early 2006 w/ M272 you may want to consider selling it.
See attachment.
There is a class action lawsuit filed for this.
Check facebook.
See attachment.
Check facebook.
On my car they changed the PCV hose, oil breather and cam plugs. This helped the oil loss but it was still there. My warranty was running out so then I started looking around and felt oil. So I took it in again (this time to a different dealer) and they said the silicone wasn't correct and oil was leaking again from the cam plugs.
Attached are pics where I felt oil. It's at the rear of the engine on the drivers side. If you move your hand down there (where the circle cap looking thing is) you will feel the cam plugs.
Thanks Karo the funny thing is that the dealership change the rear cam plugs and centrifuge cover.This was done in mid Jan.
M is doing great!!!! Been on so many business trips lately I haven't been able to drive it a whole lot. It's always a treat to take it out after driving a rental car for a couple days though. Makes me appreciate the performance and handling all over again!
Hey guys just an update. Spoke with the SA he stated that service tech said that my ML had burn up an quart an a half. This is since mid Jan when I had the oil and other work done. So now I am just waiting to hear back from them. Thanks
Hello all just an update. So get an call from my SA today. Come to find out that my ML Vin fall under the motors that were burning oil. Now SA advise me that since my vehicle has over 50,xxx on it that MB isn't responsible to cover this So they had to order an tool that dealership didn't have to test the motor to confirm this. So my question is how are they going to fix this? And should my warranty company have too pay for this? Or is this an recall? Thanks
Super Moderator
Oh! crap. You need local advice on this matter. I would go direct to MBUSA. Be polite but persistent and ask for help.
I have just helped a friend in SA with a W204 diesel that suffered early turbo failure - a brake pedal that went to the floor which the stealer said was NORMAL! & his car was dented on the hood by hail when at the dealer.
We forced an escalation to Germany - turbo has been replaced & Benz is flying a new braking system from Germany to SA including calipers - all FOC.
