2003 C230 Sedan - Settings Question
2002 CL500
Hi guys,
I'm a bit confused here - when I unlock my car with the remote, it flashes (as always) but the headlamps won't light up... same thing when locking the car. Where do I change these settings so that it lights up for 30-45 seconds? I've tried changing it under "Settings" but it didn't work for me.
2010 C300 4matic
First keep in mind that this only works when it is dark out.
When you unlock and the lights come on, that is "Locator Lighting" and is in the Settings menu. It is a simple on or off.
When locking, this is the headlamp delay feature in which you can set the number of seconds they stay on. And this only comes on if you had the headlights on while you were driving, just before shutting off the car. Or if the lights are on auto and you shut the car off with the lights on. I think it still works if you turn the lights to off instead of auto, but I'm not sure because I always use auto.
First you must turn on Locator Lighting in the Convenience Menu on the MFD. Then set your lights to Auto via the light switch. This only works at night and on my 2003 C230K SC it only works in Auto mode. The instructions are also in the owner's manual. This is a big book but the answers to most of your questions will be found in the book.
2002 C240 6-spd (ret)
MarkL on my 2003 C230K SC the locator lighting does not work in any mode except Auto. If I turn the lights to off and lock and unlock the car in the pitch black the lights do not come on. I must have them in the AUTO position for the locator to work. Maybe that was a change made between 2002 and 2003 or maybe mine is broke. I just leave my lights in Auto anyway, I just wish you could turn the fogs on in AUTO mode.
My delay works how long the lights stay on after unlocking the vehicle and locking it turns them off right away. When I first got the car I had the locator stuff all set but my light switch in the OFF postion and it never worked, as soon as I put the switch in AUTO and unlocked the car the locator lighting worked for me. If I turn my lights all the way to OFF again the locator lighting stops working.
Sorry mine do not turn off when locked they remain on until the timer runs out. I park in my garage so I do not lock it when I get out and the lights are always on afterward. I thought when I locked it they turned off but they do not. Sorry I am an idiot, this is what happens when you only get your car one day a week and on weekends. My wife has it to drive during the week, s I only see the car in the morning before I leave.
