Rear suspension - identify this part
His failure of the tie rod is caused by a crack or abnormal failure of the component as it is quite hardy and not a stamped piece of steel but rather a solid component that is casted.
Everything seemed fairly well made and the arms were no worse than any other car I have worked on.
When the front end is tight, the precision of the steering and control of the car is second to none and you don't have to correct and re-correct your steering to keep the car straight
