rim question, need help asap.!
does 18x9.5 fit in the back of the C240 ok?
wrong rims were sent, i received 2 18x8.5 and 2 18x9.5
also what size tires is recommend?
thanks in advance..
I suggest you use 235/40/18 for the front and 255/35/18 or 265/35/18 for the rear fitment.
I myself use 235/255 for the tires on my 18s.
For the rubbing issue, I think it will be allright if you roll the fender.
I have a strange experience. My front tire always rub when I try to turn, but when I install the lowering spring, they do not rub again. Moreover, I do not roll my fender.
I hope this help.
I've seen C's on 9.5's. You shouldn't have an issue until you hit 10 or 11, but you might need to roll the fender. What's the offset on the wheel?
i'll go with the 255/35/18 series then....
i really hope i dont have to roll the fenders. that'll be a pain in the neck trying to find someone around here to do it, plus the money..
the rims just came in a little earlier, i would hate to go through the trouble of sending back the 9.5" rears.
thanks again.
The ideal tire sizes are 225/40/18 and 255/35/18. I can guarantee that it will have no rubbing issue. However, it is also okay to put 235/40/18 and 265/35/18 (for certain tires only). You will have a rubbing problem with PZero Rosso but you will be okay with Toyo T1-S on 265s.
9.5s will definately fit in the back... the rear can fit up to 10 comfortably. i have 19x8.5 front and 19x9.5 rears and they are fine. i use 235/35 front and 265/35 rear.
yea sorry, typo... what i meant was that i have 265/30... you are gonna defiately have the shaved, rolled or grinded....
If it's fender rolling, I'm totally cool with that...
if you were in LA.. i could recommend you some good places... but since you arent... sorry i cant help you there.
Anyone knows any good-reputable shops in Chicago area for fender rolling etc? I can only think one shop, MotoPersona...
