2002 c240 no start
Old Apr 4, 2011 | 02:12 PM
junior212's Avatar
2002 c240
2002 c240 no start
MY 02 C240 WONT START UNLESS I DISCONECT NEGATIVE BATT TERMINAL AND RECONNECT IT. ANYONE HAVE A CLUE ON WHY THIS IS HAPPENING?
Old Apr 5, 2011 | 06:32 AM
Silver C's Avatar
C240
Will it crank first or no crank at all? Does it happen everytime and works everytime you disconnect and reconnect the negative terminal? Need more info here..
Old Apr 5, 2011 | 02:51 PM
junior212's Avatar
2002 c240
no start
I replaced the battery and it started. when i went to start it again i got nothing. everything else has power but it doesnt crank. when i disconnect the ground wire at the battery or at the drivers side strut tower it will start everytime, and run fine. but when i shut it off it wont start again.
Old Apr 5, 2011 | 08:00 PM
samaritrey's Avatar
Super Moderator
THE C350
CPS possibly otherwise no clue. GL
Old Apr 5, 2011 | 08:57 PM
C230 Mulac's Avatar
1999 E320 4matic Wagon, 2005 C55 AMG - sold, 1998 VW Jetta TDI - sold, 2006 C230 Sport - Totaled :(
so everything else has power but it doesnt crank? sounds like maybe a bad starter, but then it wouldnt matter if you disconnected and reconnected the battery...i've never heard of anything like this before, maybe it's some sort of electrical/programming glitch? who knows with all the electronics in these newer cars
Old Apr 5, 2011 | 08:59 PM
C230 Mulac's Avatar
forgot to ask have you done anything with your ecu? tune it or anything? cause when you disconnect and reconnect the battery it resets the ecu, so maybe someone did a bad tune on it? if not, then maybe something is wrong with the ecu, how many miles are on the car?
Old Apr 5, 2011 | 09:16 PM
Silver C's Avatar
C240
Yeah disconnecting battery resets the ecu, you have one funky ecu right now, probably best way is to get someone with a software and diagnose it for you..
Old Apr 5, 2011 | 09:22 PM
Glyn M Ruck's Avatar
Super Moderator
Could be starter motor relay buggering around. Just pray it's not the EIS.
Old Apr 6, 2011 | 12:04 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
yea, try replacing CPS first...
Old Apr 6, 2011 | 05:40 PM
mskembo's Avatar
2010 Mercedes-Benz E350
This sounds disturbingly similar to the intermittent no-start issue that plagues the W202s. No beuno...
